10-22-2019, 04:34 PM
COLD, CAULK, and CUSTOM DIY WINDOWS
So I am going to remove the bus windows and replace them with house or custom windows and sheet metal.
Has anyone worked with caulking for the windows in the cold? Right now we're in the mid 60s during the daytime and mid to low 30s at night. Any recommendations?
I've gone to a few places, like the Habitat for Humanity Re-stores looking for windows, but haven't found any that fit and open. I am not going to do a roof raise, so need them to feet within a 28.5" height. I can go wider than the standard 25" by chopping off a column.
So I am considering making my own windows using steel angle and tubing.
Anyone done this?
My idea is to weld up some double pane windows with steel frames, and hinge them on top with a piano hinge. Between the piano hinge and the bus will go a strip of roofing rubber.
Between the panes of glass will be a spacer with some kind of foam cushion-maybe butyl tape.
Not sure what to use as caulking, but thinking of the 3M marine adhesive, since its meant for water environments. Unless butyl tape will work and I attach using sheet metal screws.
Would rather find premade windows, but I can't keep driving 100-200 miles each way for the chance of finding what I need, and the window to work before winter is here is getting narrower.
10-22-2019, 04:52 PM
Glass in vehicles is always tempered. As long as there’s no accident it won’t matter.
Have you considered a poor man’s double pane using Mylar?
10-22-2019, 04:55 PM
Not all glass.
10-22-2019, 05:00 PM
I'm thinking the windows behind the driving compartment are fine not tempered. I may cover them with hurricane film.
Mylar scratches too easily in my opinion.
I do need to get a window for the passenger side though. That has to be tempered.
10-22-2019, 05:05 PM
I was referring to that thin Mylar film that’s used to make an airspace and keep drafts out. It’s applied with double stick tape and a hair dryer. By no means a permanent solution, but it was enough to keep my leaky apartment from being an icicle during the cold months and you can do it for about $30.
10-22-2019, 10:17 PM
Not a bad idea, but if I'm gonna go through the trouble of making windows, I'd rather just do it right the first time.
Hopefully I'll find some usable windows soon and solve the issue. I have a double glass window now that doesn't open. I may use it for one of the windows anyway. I only really need two to open.
10-23-2019, 12:10 PM
Coachwork: Tomas
Engine: 7.3l
Here's mine
Two in back two in front, small one for bathroom (middle)
10-23-2019, 12:22 PM
WOW!
Those look great!
Where'd you find those?
10-23-2019, 12:35 PM
Coachwork: Tomas
Engine: 7.3l
Found
WOW!
Those look great!
. I found them on Kijiji for 200 canadian. Their stormtech, which is company that's out of business. Was alot of work but Id do it in a heart beat. I recommend changing bus windows if it's somthing you can do.
10-23-2019, 01:41 PM
OK thanks!
DEFINITELY CHANGING THE WINDOWS!
I may put home windows in-if I can find the right ones.
10-23-2019, 09:08 PM
I found house windows in a hidden little warehouse near where I live.
$20 each for the large, non-opening windows.
$30 each for the smaller opening windows.
I am considering putting a piano hinge on the larger ones so they can tilt open,but with the other windows that open, and the huge entrance/exit door, plus the fans I'll put in, its probably unnecessary work.
But I have a bit of a dilemma...
I did a mock up of the window sizes for the bus, and I'll have to cut off some of the window pillars.
I'm thinking of creating a steel frame for the new windows for reinforcement, and welding up an "X" steel reinforcement in the area between them with 16 gauge steel sheet covering it.
Alos thinking buses are far stronger than RVs, so that's another factor.
What do y'all think?
10-23-2019, 09:16 PM
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
Attachment 38807
I don't know about where you live, but I imagine it's the same as here, all glass in vehicles or trailers has to be tempered safety glass
10-23-2019, 09:37 PM
I think all custom windows in the bus should have a steel frame to them. I may add one more to my bus that may not have one only because it is ust under 24" and will fit between ribs just sandwiched between the skins.
10-23-2019, 09:42 PM
I'm thinking of applying the hurricane lamination to the windows. Its a clear film that keeps the glass from shattering all over the place.
10-23-2019, 09:43 PM
Good point. I will make steel frames for them.
10-23-2019, 09:51 PM
In mine I just ran bars between whatever rib space was left and then uprights to secure the window. Mine were all trim ring sandwich type. I cut the ribs at the height of the window so the new bars tied them in.
10-23-2019, 10:01 PM
In the bigger window I have maybe 4" of extra space top to bottom.
In the smaller windows I have about 11" between top and bottom.
Room enough for some kind of frame.
You don;t think the windows are too big/too much cutting of the window beams?
10-23-2019, 11:00 PM
Coachwork: Tomas
Engine: 7.3l
Sounds like it be a simple Frame in Frame Idea then?
10-24-2019, 07:28 AM
Indeed.
We'll see just how simple when I get it installed!
10-24-2019, 09:16 AM
Coachwork: Tomas
Engine: 7.3l
True
That's so true, you can do it
