Old 05-30-2021, 05:34 PM   #21
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
Originally Posted by kidharris View Post
For the record, those rooftop A/C units are called "self contained units" (because the evaporator and condenser are in the same box, like a window unit)
Are you going to put a generator on the trailer?
I'm wondering if anyone here has taken the original bus system, combined it all into 1 box using a small gas engine to drive the compressor?
those would be called APU's like on a refrigerated trailer.
auxilliary package units.
Old 05-31-2021, 12:53 PM   #22
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
Noted, however, refrigeration systems and air conditioning/hvac systems have different requirements.
Still wondering if any one has "recycled", so to speak, their bus air conditioning system ( compressor, condenser, evaporators, fans) into a self contained system with a small engine driving the compressor.
or
has anyone just hooked up the compressor to a small engine and re-routed the refrigerant lines and left the rest of the system intact/inplace?
Either one would allow the use of the a/c regardless of whether the bus engine is running. Probably require a fairly large "small" engine with electric start. cheaper? too much noise? too much space?
Old 05-31-2021, 02:12 PM   #23
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
Cool
Yes. This is possible. Search "pony motor ac", etc
Maybe JoeBlack did this?
Some buses do have two engines.
https://www.skoolie.net/forums/f10/w...nes-17161.html
Old threads.....answers from decades of possibilities.
Frederick Douglass: "If there is no struggle, there is no progress.”
