Old 05-12-2021, 05:02 PM   #1
witchywoman's Avatar
Year: 2006
Rated Cap: 30
Covering the crack between wall and ceiling
What did you guys use to cover the crack between the inner walls and the ceiling?
I’m painting the outside of my bathroom and there is 1/4 inch gap between the wall and ceiling. I can’t find any trim that is bendable.
witchywoman is offline   Reply With Quote
Old 05-12-2021, 05:27 PM   #2
Chassis: G30~Chevy cutaway
Engine: 5.7/350 Chevy Vortec
I've seen a bus owner use rope glued over the gap you're looking to cover.
Don't know if that goes with your interior motif, but it might be a lower cost option if you think it will work?
Good luck, and post pics of your "solution"...
Old 05-12-2021, 06:57 PM   #3
1/4 round comes in many widths and is bendable. The rope idea works well also as there are any types and size of rope you can use. Bendable and make 90* turns around corners, glued or tacked with brads.
Old 05-12-2021, 07:51 PM   #4
Year: 2006
Rated Cap: 30
I’ll have to look at both options. I thought getting the curve was the problem, Ha! I forgot about the dumb gap. Thanks!
Old 05-12-2021, 08:00 PM   #5
We embraced the gap. It's about a uniform 2" on 3 sides and it keeps it from getting too steamed up from the shower.
Old 05-12-2021, 10:10 PM   #6
s2mikon's Avatar
Engine: Cummins 8.3
Polyurethane body seam sealer? It’s paintable and flexible.
s2mikon is offline   Reply With Quote
