Old 10-18-2021, 10:47 AM   #1
kimberlybennett234's Avatar
Year: 1968
Chassis: Super Coach
Engine: 262 Cummins
Rated Cap: 96
Crown bus Gulmite screws
Anyone know where we can get a 32 point GULMITE driver/socket or have an idea what else we can use to unscrew these?
kimberlybennett234 is offline   Reply With Quote
Old 10-18-2021, 11:27 AM   #2
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Unfortunately, Gulmite drivers and sockets are super hard to find. We have 3 Crown buses and I've only been able to get lucky to buy one sized socket. For all the other sizes, I use two different "screw removal" pliers. One is a pair of Vamplier screw removal pliers and the other is an Engineer brand. I ground the end of the Engineer pliers, to make the tip smaller for better access into tight spaces. If the larger Vampliers fit your spaces, though, they're super sturdy pliers and work well for lots of things besides Gulmite screws.
I just posted photos of both brands of pliers in another thread here, just last week. Here's a pic of the ones I ground down:
Old 10-18-2021, 12:40 PM   #3
Year: 1968
Engine: 262 Cummins
Rated Cap: 96
Thank you so much.
Old 10-18-2021, 01:37 PM   #4
flattracker's Avatar
Engine: Cummins 350 big cam
Rated Cap: 86 passengers?
Until the other day, I didn't know those pesky "Crown screws" had a formal name. I encountered them in the 1973 Crown I parted out years ago. I recall that I used a Dremel to cut screwdriver slots in many that I removed. Fortunately neither of my other Crowns used them. They do use a lot of pop rivets though. Welcome to the forum though. Are you starting on a conversion or is your Crown already done?
flattracker is offline   Reply With Quote
Old 10-18-2021, 02:45 PM   #5
s2mikon's Avatar
Engine: Cummins 8.3
Gulmite was also used in older maytag washers. Look for a retired maytag man.
s2mikon is offline   Reply With Quote
Old 10-18-2021, 02:49 PM   #6
Maytag uses a 33 point screw.
Old 10-18-2021, 02:50 PM   #7
s2mikon's Avatar
Engine: Cummins 8.3
Okay. How about a center punch and a reverse drill bit?
Old 10-18-2021, 03:26 PM   #8
Year: 1968
Engine: 262 Cummins
Rated Cap: 96
My Father-in-law got our 1968 Crown bus about 20 years ago and did convert it but he only insulated it behind built ins. We need to add insulation where the original panels are and have to remove many, many of those screws. Thanks for the info!
Old 10-18-2021, 03:27 PM   #9
Year: 1968
Engine: 262 Cummins
Rated Cap: 96
Thanks for the idea!
Old 10-18-2021, 03:28 PM   #10
Year: 1968
Engine: 262 Cummins
Rated Cap: 96
Thanks for the reply.
Old 11-06-2021, 02:02 PM   #11
How about taking a socket that is slightly larger and filling is with just mixed epoxy putty. Place the socket full of putty over one of the bolt heads until it dries. Pop it off and you should have a socket with a perfect tight fit for the bolt heads.
Eitek1 is offline   Reply With Quote
Old 11-06-2021, 04:41 PM   #12
When I parted out a 73 Crown years ago it had many of those pesky screws. I used a dremel to cut a screw slot in the head and they came out with a screwdriver.
