03-06-2019, 11:14 PM
#41
I cut mine all the way to the front
No seam.
Then I ordered new windshields.
03-06-2019, 11:58 PM
#42
Engine: 6-71TA
Rated Cap: 90
No seam.
Not sure what you mean by no seam? Do you mean no transition?
03-06-2019, 11:59 PM
#43
Exactly no transition.
You can see mine on my build page. Or my IG @thebbbus
03-07-2019, 12:03 AM
#44
Engine: 6-71TA
Rated Cap: 90
Yeah, i just saw your other BB post
Btw, how did you handle the drywall gap?
03-07-2019, 12:27 AM
#45
Since I removed all the windows and don’t need a path for water, I’m sealing it from the inside and just spray foaming it.
03-07-2019, 08:38 AM
#46
Engine: 6-71TA
Rated Cap: 90
I am also not using the original windows and have removed them. How are you sealing it from the inside other than using spray foam? Are you adding any metal material?
I have heard others just using spray foam but I do not want to just rely on foam to seal a gap that large.
03-08-2019, 01:43 PM
#47
Coachwork: Crown / Pusher
Do you have any more pics of your raise? Also, how did you handle the gap that runs along each side of the Bus which is for the window dry wall construction?
Sorry I've been real busy & havn't been on much, far as the gap goes I slide sheetmetal in & riveted then sprayed Flexseal inside at the seam. Is there any thing specific your wanting to see far as more pic goes
03-09-2019, 01:50 PM
#48
Engine: 6-71TA
Rated Cap: 90
No problem, thanks for the pics. The two things I am not sure about is how I want to handle the drywall gap and the roof raise transition.
For the drywall gap, I considered removing and replacing the entire side panels but that is a lot more work and also reduces strength and rigidity. I will likely do something similar as you and use riveted sheet metal with some type of sealant. If you have more pics of what you did on yours would be great.
For the roof raise, I looked at the option of doing a transition then thought raising the whole top might work better. After looking at a couple of full top raises, I realized that the ones I looked at were older Crowns with windshields that were shorter in height or were different with respect to the side windows. After looking at your Crown which is only 2 years older than mine, I got a better perspective of what mine would like with a roof transition and the approx. location for the cuts. Any more pics of the transition from inside and outside would help. Again Thanks!
09-02-2019, 01:47 PM
#49
Engine: 6-71TA
Rated Cap: 90
Been a while since I have made progress on my Crown (various reasons...life).
Raised the roof 16" yesterday (not welded in place yet). There are only a few that I know of who have done this to a Crown.
09-02-2019, 03:02 PM
#50
Looking good. Nice to have a shop to do the work in too. Hope the shop door is tall enough to get out! Lol. My Crown (formerly built for Hewlett-Packard in ‘66) has a factory 7ft ceiling height. Keep up the good work! Also realized were only 5 hours apart (in Nebraska); awesome to see another midwestern Crown
09-03-2019, 12:30 AM
#51
Engine: 6-71TA
Rated Cap: 90
Thanks. The shop door is 13.5 ft. I think the Crown was just around 10 ft. before the raise, so now around 11.5 ft. tall. If mine was 7ft. like yours, I would not have raised it. However, I am around 6'1 and was barely able to walk straight before the raise. My son is a bit taller, so the height would not be sufficient with insulation in both floor and ceiling. Glad there are other Crowns in the area. I know of one other in Missouri.
03-19-2020, 02:41 AM
#52
Delete, delete, delete
03-19-2020, 02:48 AM
#53
Originally Posted by Bluespoet
the worst thing you can do is say **** it and do it without plumb bobs, without bracing and the outer shell moves and then you really have a problem, if you run out of money during the surgery, best to wait till you have the money, plan on doing it right or it will go wrong.
I misread your post and tried to retract it but this forum won’t allow it, sorry
