Old 11-08-2021, 02:53 PM   #1
Year: 2014
Coachwork: IC BUS
Engine: Maxxforce 7
Question Cut Off Stop Signs now my air door isn't working
Hi all. Hoping someone can give me some advice. I have a 2014 IC CE300 that I'm starting the process of converting into a RV with. I ended up pulling fuses until I found which ones ran the stop sign lights and master switch. thought all was well until I went to open my door with the steering wheel control. When I flip the emergency switch to automatic the doors close as normal but when I push the steering wheel switch I hear what sounds like a relay to the left of me probably coming from the relays/fuses but the door doesn't move. If i switch to emergency open the doors will push open manually with my hand and when I flip the switch back to auto it will slam shut. Not sure what's going on. I've tried adjusting the pressures valves in the fuse panel outside and that hasn't made a difference. When I open the top of the door's compartment, it has air pressure according to the PSI gauge. Not sure if there is some failsafe that will stop the door from opening when the stop signs aren't functioning? Anyone have any ideas? I've checked fuses and everything seems ok.
Thanks in advance!
-Shield
Shield1984 is offline   Reply With Quote
