Old 09-17-2023, 11:56 AM   #1
Cutting out mold
Bus has had leaks, led to mold underfloor. I need to cut out sections of floor and clean/remove/disinfect area. Best tool and technique for this? Multitool? Sawzall is too inaccurate, I need precision.
Best way to add in flooring after the fact?
Appreciate any responses.
Kwest364 is offline   Reply With Quote
Old 09-17-2023, 12:50 PM   #2
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
if its just mold and not rusted through metal then get a product called mold stat.
it works and is what the pros use for hurricane clean up repairs and for any kind of water damage.
5 years ago a hurricane took half the roof off of my house and that stuff is what saved my trusses. a couple of treatments and i have not had any mold come back and that is with gabled louvres allowing air ventilation.
of course it is very strong and a concentrate so follow the instructions and safety.
Old 09-18-2023, 08:20 AM   #3
Thanks for the tip. I'll pick some up.
I'm still going to cut out pieces of floor and clean and replace. Thoughts on best tool/technique? Oscillating multitool seems best thing to use to my eye.
Old 09-18-2023, 09:11 AM   #4
Engine: DT466e 215hp Allison 2500
You could use a skillsaw by adjusting the cutting depth. That's what I did around the driver seat.
Timeline is offline   Reply With Quote
Old 09-18-2023, 09:54 AM   #5
Chassis: chevy
Engine: 3116 catapillar
yea this would be the easiest just make sure it wont hit the metal.
mmoore6856 is offline   Reply With Quote
Old 09-18-2023, 10:06 AM   #6
nikitis's Avatar
Rated Cap: 29
Depending on the size you need to cut out, but a grinder will work as well. That rubber will smell horrible though using it as it burns the rubber in the process, but you can cut pretty precisely and once you see sparks, you know you're through.
