Old 02-11-2024, 12:53 AM   #1
Dance pole...
There is a requirement for a dance pole to mount some where on the bus. I'm thinking passenger side and my question is does anybody have experience with mounting anything on a unit that will need to endure a pretty substantial dynamic load.
My initial thought is to reinforce a 2 hat channels, strap the outside and attach a cantilevered arm to said strap made to swing and pin to the bus for transport
Thanks
ChibaPrime is offline   Reply With Quote
Old 02-11-2024, 06:54 AM   #2
La Camioneta's Avatar
Year: 1994
Chassis: Ford B-700
Engine: 12V 5.9
Distance out from the side of the bus?
Take a boat trailer tongue the length you want, drill and pin it to your reinforced top plates with some tractor implement pins https://tractortoolsdirect.com/lower...pins-set-of-2/ ? It would not rotate, but would be easy to remove and stow.
Replace the hitch with a pole cap and spread the bars to your liking before mounting.
La Camioneta is offline   Reply With Quote
Old 02-11-2024, 07:52 PM   #3
It needs to be around 6 feet out from the bus 9 feet tall.
It's at compression poles to its need 2 surfaces to brace it self top and bottom
Old 02-15-2024, 06:00 AM   #4
Year: 1994
Chassis: Ford B-700
Engine: 12V 5.9
Here's one from FB
