Old 08-05-2022, 11:06 PM   #1
Year: 2006
Chassis: International CE300
Demo help
2006 International CE 300
During demo should i remove the beige steel base around the bottom. Not sure what it is called. Its below the silver metal underneath the windows.
Uploaded pic..
KipperTheKoolBus is offline   Reply With Quote
Old 08-05-2022, 11:19 PM   #2
It's called the chair rail and it's how the walls are attached to the floor. You can't remove it without destroying the bus, so ... don't remove it.
These two videos show how your bus is constructed (the video shows an International but Blue Birds and Thomases are built in similar fashion):
Starting at 0:51 in the second video, you can see the chair rail and the ribs of the bus being attached to it.
Old 08-05-2022, 11:37 PM   #3
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
That's Right
As Musigenesis stated...
(Still shots)
First, the chair rail is attached to the chassis.
Then the ribs are attached to the rail.
Cutting it would disconnect the floor from the walls.
Old 08-06-2022, 07:57 AM   #4
Year: 2006
Thank you so much, i will watch the videos.
