Old 06-29-2020, 04:53 AM   #21
Originally Posted by 1970BlueBird View Post
Hey I found this thread while digging around. I bought the bus, drove it back to NH and she ran great. Didnít even change a fuel filter. Now I am tearing it apart and getting a little too OCD. I paid 5k and was planning to outfit and run it. Now Iím getting carried away which I didnít want to do. Anyone around for moral support lol. Northern NH here.
Is that a wanderlodge??
Old 06-29-2020, 06:13 AM   #22
Originally Posted by BigPaul367 View Post
The red color is a tip-off that this engine was rebuilt at one point. ALL original engines where original Detroit Green.
Not entirely. Silver Series motors from the mid-1980s onward are, well, silver. I have also seen a fair number of stock original DD motors in fire fighting apparatus that were red, but never a 53-series in my experience. The were all 92-series. I've even seen a Silver Series 6V92T painted red in an as-delivered Seagrave pumper, I think the apparatus mfrs repainted them because they fitted pumps and ptos to them, so it made sense to paint the whole lot together once they added their stuff to the motor...
The 6V53T, especially the aluminum block version, was a favorite of the US military for many, many years. Many of these Department of Defense surplus rebuilt, even brand new motors are still crated and sitting around in various places. Most common powerplant of the P-boats in Vietnam. Its a nice milspec engine because its field rebuildable, reliable, and will run on all manner of contaminated and crappy fuel, if only for a while. Even better, the DD 2-cycle is immune to EMP weapons (atom bombs and death rays) having no electrical system at all, if equipped with an air starter. Your government dollars at work...
TomA is offline   Reply With Quote
Old 06-29-2020, 10:23 AM   #23
Coachwork: Winnebago
Chassis: Ford F53
Engine: Ford Triton V-10
Rated Cap: currently 2
A Wanderlodge with a roof raise maybe?
Sehnsucht is offline   Reply With Quote
Old 06-30-2020, 05:29 AM   #24
Crown_Guy's Avatar
Coachwork: Crown Coach
Chassis: 40ft 3-axle 10spd O/D, Factory A/C
Engine: 300hp Cummins 855
Rated Cap: 91
Originally Posted by Iceni John View Post
The 6V53 is a little screamer - it revs higher than the later 71 and 92 series engines, and because it's a two-stroke it sounds like it's turning twice as fast as a four-stroke. Torque isn't high, so you'll need to keep its speed up, but like any Detroit they can be run on the governor all day, provided their cooling system can keep up with it. The US military is still using them more than half a century after they were introduced, and Crown used them in some of their rear-engine Embree buses. For a 30-foot bus you should be seeing 10 MPG or better: folk with 35-foot Crowns with 71-series Detroits, even converted ones, are seeing 10 MPG or slightly more, and when I helped bring a friend's 40-foot 10-speed 6-71T Crown tandem back from Northern California it also was getting 10 MPG over the 500 miles, including going over Tehachapi.
Is the engine a turbo? You called it a 6V53T. If so, they're better than the gutless non-turbo 6V53. What transmission does the bus have? In those days there was a six-speed Allison HT70, but they're getting very rare now. Was the cooling system replaced when the 6V53 was installed? All two-stroke Detroits need an effective cooling system in top condition, or they WILL overheat: you need to carefully check the bus's radiator etc., otherwise you'll be having constant overheating problems.
Good luck, John
I'm the guy that bought ALL the Embree Fleet number 60 Series Crowns and still have two of them in perfect factory delivered condition and equipped. They were all 35 ft two axle full air ride suspension with immense amounts of extra cost charter options added. They were rear mounted 6v53 non-turbo 195hp engines which was totally unheard of for Crowns at the time(1962), totally custom engineered and spec'd by and for Embree Buses. They all had an Allision 6 spd transmission the exact model I can't seem to remember now(MT66X??). The engine/transmission combo was extremely popular at the time for use in Trash trucks and if you were around then you surely heard the screaming demons in the morning waking you up with all the racket. But boy did they sound nice, nothing like the smell, and sounds of a Scream'n Jimmy.
All this previous advice is spot on and should be heeded as the gospel truth.
I noticed something that got my curiosity up. Did you say weather this Blue Bird was originally a front engine bus and this guy swapped ends and mounted the '53 in the rear??? It sounds like that when you mentioned how he extended all that structure to the rear to accommodate the new '53 engine installation. If this is the case I would be much more concerned with the overall vehicle weight distribution, chassis loads and axle weights on the ground. I'm thinking of center of gravity, turning moments when underway, possible light loading on the steering axle and much evil flowing from that. All in all swapping the engine from end to end on a somewhat lightweight school bus chassis could be too much excitement for even me to want to deal with. If it was already a rear engine vehicle and all he did was add the heavier diesel then you should be able to manage but make sure you check the axle loading and suspension tuning to insure safe handling at all speeds. Weight behind the rear axle is nothing to ignore and should be considered.
If cared for and driven like you're always mad at it.....that's no joke, then you should get many happy years of service and enjoy the notoriety you'll garner. Oh, and don't expect to get any more than about 6-7mpg out of it.
One other thing to be aware of and this could be crucial, now that I think of it.......Be sure to check and make sure if the block is aluminum (Military only) or a real solid Cast Iron commercial Block. If it's a Military aluminum block they really don't have the expected lifetime of a cast iron block. The Military M113 APC used an 8v53TT (twin-turbo) with a designed rated lifetime of only about 300 to 400 hours.....no joke. You can get them around and about in crates as stated before, but if you really want one bad enough you better get several for when they break and die so you can swap in another new one from a crate, which is of course what the Military expected and always did......Commercial cast iron blocks didn't have these built in life-ending quirks and would run and allow for in-frame repairs and rebuilds, Commercial don't you know. Long lived, repairable, efficient, cost-effective, Capitalistic, Profit generating, unlike a Combat Vehicle engine life cycle measured in hours. I'm not really sure if there was ever a Military Aluminum 6v53 or not, just a random thought I wanted to throw out to consider.
Detroit Diesel 2-strokes are truly a fun adventure with all sorts of excitement but you must be prepared for all the hilarity and ups and downs, and mechanics are getting very hard to find who still really know how to work on them correctly. Pure mechanical and will come through an Atomic Zombie Apocalypse along with the VW beetles and cockroaches. Have fun.
Crown_Guy is offline   Reply With Quote
Old 06-30-2020, 09:24 AM   #25
Chassis: International 1753
Engine: 6.9 International
The apc's used the aluminum 6v53.
I think the 6v53tta was rated at some 400 HP. I'd have to look it up to be certain.
I'm unaware of any alloy 8v53 blocks. Honestly, there were very few 8v53 engines ever made. IIRC the stress was too much and the 8v53 engines had crank breakage issues.
Numerous 8v71 and 8v92 engines made, but they're lower revving then the 53 series.
Old 06-30-2020, 09:50 AM   #26
Google says this-
The 6V-53 (210 hp) powers the widely used M113A1 and M113A2 family which has evolved into the 6V-53T (275 hp), powering the upgraded M730 Chaparral and M113A3 vehicles.
400 hp would be a lot from such an old 300-ish cubic inch engine, wouldn't it?
Old 06-30-2020, 10:28 AM   #27
Yes it would. Which is why they used it. Compact and powerful.
Here is what my google revealed.
Army Guide
I had an instructor in college that worked for detroit diesel in the late 90's, he's the one that told us that.
Also, only the mechanical detroits were emp proof. The later ones were adapted to use ddec.
diesel pusher, dieselkits, dieslebusengine
