floor that squeaks...
I live in a house built about 100 years ago, and has been moved about three miles from where it was built in 1960. I have so many floor squeaks I can not count them all. Nor are my floors flat and level.
My bus is kinda the same way. I dont really care about a squeak here and there. I used the pink foam 2" and 3/4" plywood on top of that. I do not have any wood framing structure - steel floor - 2" foam- 3/4" plywood. The stuff like seats, cabinets, refrigerators, toilets, beds, that bolt to the floor and walls are what hold most of the ply/foam floor in place. There are assorted bolts that go all the way through to hold an edge or corner down here or there.
Nope I cant stand all the way up in some places. That's okay If I sit down all is good. I think that 2" and 3/4" of wood is a hell of a lot better than kinda rotten plywood floor over steel.
If I could convince ---- I would tell you "It doesn't have to be perfect, just good enough."
william
