RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 03-24-2020, 04:07 PM   #1
Chassis: Wayne Lifeguard
Engine: 7.3L IDI
Rated Cap: 23,600 lb
DIY Fuel Tank
Hi all,
Currently I have two fuel tanks, a 35 gallon and a 20 gallon with an electrical selector valve. The valve has not been reliable and it's annoying having to fill two tanks. I'd like to go to a single, 70-100 gallon tank.
I'd prefer to buy a used, professionally built tank, but I've found it hard to find a rectangular tank that fits my space efficiently. The space I have available under the floor is 58" long by 26" wide.
I have the facilities, tools, and skills to build my own tank but I'm wondering about the rules regulating tanks on RVs. Does anyone know what's allowed or have resources to how DIY tanks can be built?
Any ideas about DIY tanks or resources for commercially available tanks?
I'm in Arizona, if that makes a difference.
AzironaZack is offline   Reply With Quote
Old 03-24-2020, 05:12 PM   #2
Chassis: chevy
Engine: 3116 catapillar
Rated Cap: formerly 71 now 2 or 4
call your local dot and speak to a truck inspector i wont do anything like that
mmoore6856 is offline   Reply With Quote
Old 03-24-2020, 06:04 PM   #3
I had a 1977 Ford based class C motorhome. It had a fabricated rectangular box for a fuel tank. So at least 40 years ago, manufacturers could do that.
That said, I think I'd be looking at a 55 gallon tank from a recent Ford cutaway, or a 75/80 gallon one from a Class A Ford motorhome. The Class A one is probably too big though, it's around 63.5" x 27" x 14". It has about 25 gallons of vapor space though, a bit more than the 10% DOT requires for diesel tanks. The 55 gallon one is smaller than the Class A. It's 36.25" x 31.75" x 16.75". Sure 26" is all you have? Going between the frame rails? Aren't they like 34" wide?
ennonne is offline   Reply With Quote
Old 03-24-2020, 06:15 PM   #4
Engine: 7.3L IDI
That's what I was thinking, too. I've seen older RVs with straight up shop-made rectangular tanks, hence my consideration of building one myself.
This will be going on the side of the frame rails between the rear wheels and the stairwell. The gross available space is 64" long by 30" wide with a maximum height of 22" (although I'd like to keep it under 16" tall for clearance and looks).
I can find plenty of truck fuel tanks that fit the length but they're typically cylindrical and are too big in diameter. Rectangular is what I need, for sure.
Old 03-24-2020, 10:42 PM   #5
sportyrick's Avatar
Chassis: F33695
most boats have rectangular tanks, find one!
Old 03-24-2020, 11:20 PM   #6
Might be worth a call to Arizona RV Salvage in Glendale/Phoenix. They might have something.
Old 03-24-2020, 11:22 PM   #7
Engine: 7.3L IDI
Thanks, all! I hope you're staying safe and sound out there.
Old 03-25-2020, 12:57 AM   #8
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
this one might do you
new,,,,,,here is a link
https://www.facebook.com/marketplace...4191673273160/
william
Old 04-08-2020, 05:55 PM   #9
Year: ‘09
Chassis: Vision
Engine: 6.7
Rated Cap: 35’
AAA Bus Sales in Phoenix has all sorts of used bus parts. If he doesn't have one, I'm sure he can get you one.
Ranchorossa is offline   Reply With Quote
Old 04-08-2020, 09:54 PM   #10
Engine: 7.3L IDI
Thanks! I’ll give them a ring!
Old 04-09-2020, 12:39 AM   #11
Just put a crossover line. So that both tanks are connected at the lowest point. Secure the cross overline so it doesn’t get ripped off if you hit a pile
Of trash in the road.
Dirtdoctor is offline   Reply With Quote
Old 04-09-2020, 03:00 PM   #12
Engine: 7.3L IDI
Interesting idea but the tanks are at different heights and a crossover line would end up overfilling the lower tank.
Old 04-10-2020, 04:52 AM   #13
em bothh
Seal up or remove and seal up the lower tank's filler tube.
Put in the cross-over tube and draw fuel only from the lower tank.
Fill them both from the higher tank.
Old 04-10-2020, 11:54 AM   #14
Engine: 7.3L IDI
Seems to me that a crossover system would introduce a couple of dangerous conditions. If you fill the lower tank from the upper how do you leave 10% headroom in the lower tank? When the lower gets to 100% full the fuel would start spilling out of the tank vent. Also, a small crossover tube would take ages for the lower tank to fill from the upper when fueling up, but a big one would be scary easy to dump all the fuel with in the event of damage. Lastly, hasn’t gravity feed been against the rules for a long time?
A single tank is the simplest way to go, I’m thinking.
I appreciate the ideas! Thanks!
Old 04-10-2020, 02:02 PM   #15
Year: ‘09
Chassis: Vision
Engine: 6.7
Rated Cap: 35’
Single tank. Make it easy on yourself.
Old 04-10-2020, 02:29 PM   #16
Chassis: chevy
crossover lines along with bottom feed are no longer allowed. too many got hit and broke off so the fed dot outlawed them. suction tubes are your only choice as for fuel supply. if you want a second tank you must use a duel draw/return or install a pump to pump it to your feed tank. if you use a duel draw the tanks must be the same height
Old 04-17-2020, 10:29 AM   #17
Engine: 7.3L IDI
So I found a couple suitable, factory made fuel tanks. One is 75 gallon and the other 100, so either one is a good upgrade.
One question remains: is it okay to put a side mount tank BEHIND the rear axle? The NFPA is explicit about the rules for propane tanks behind the rear axle but I’m having trouble finding definitive answers regarding a main engine fuel tank.
