Old 01-19-2021, 11:00 AM   #1
Engine: Cummins 8.3
Does subfloor foam sqeaek while driving?
I have seen several people using foam panels in the subfloor of the bus. This seems simpler than other solutions, but is there a constant squeak every time you hit a bump, like the sound of rubbing styrofoam? I recently had a road trip with a styrofoam cooler that squeaked the whole way. I feel like this sound would make me snap halfway through the trip.
Thoughts?
Truffles is offline   Reply With Quote
Old 01-19-2021, 02:50 PM   #2
s2mikon's Avatar
Engine: Cummins 8.3
I used eps in my floor and it doesn't squeak. I do have a constant whining noise going on but that is caused by... oh never mind
s2mikon is offline   Reply With Quote
Old 01-19-2021, 07:41 PM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
I have 2 inch with pex in it for heat. Some squaks when you walk on it, I think it's the pex. Nothing when driving.
Old 01-20-2021, 08:19 AM   #4
Engine: Cummins 8.3
Do you have heated floors like somewhereinusa mentioned?
Old 01-20-2021, 08:20 AM   #5
Engine: Cummins 8.3
Do you have expanded polystyrene (little white balls compressed together) or extruded polystyrene (often pink, more solid form)?
That’s a good point about the heated floors on the foam subfloor.
I what kind of hard surface did you put over the foam?
Old 01-20-2021, 09:50 AM   #6
Chassis: AARE
I used the pink stuff . Floor is 3/4 plywood that has some sort of plastic coating on both sides.
This doesn't squeak.
Old 01-22-2021, 08:50 AM   #7
Engine: Cummins 8.3
Perfect. Thats exactly the direction we were planning on going with the xps, heated floors, and plywood. I feel more comfortable about it now.
