Old 06-07-2021, 07:54 PM   #1
bigskypc50's Avatar
Coachwork: AMTRAM
Chassis: INT
Rated Cap: Big Girl
Doing it again
Hey guys, well I am buying a 2nd bus. I need another bus like a hole in the head!
Wanted to get your thoughts on it, 1995 bluebird gas/propane 366 AT545 and 6.17 rear end. But it has 280k miles on the clock and they have no records of it being rebuilt engine or trans. But they did not own it since new. It starts right up has good oil pressure. Trans go’s into gear fine. Can’t drive it as it’s still in there fleet, was running kids Friday on the last day of school.
What’s you thoughts? My plans are a small low end conversion and since it’s only 29t long, I want to use it for local trips and I need a wheelchair lift, family member is in wheelchair. So it will be lucky to see 3000 miles a year now.
Price is scrap price 1k.
bigskypc50 is offline   Reply With Quote
Old 06-07-2021, 08:47 PM   #2
Originally Posted by bigskypc50 View Post
6.17 rear end
Woo hoo! I'm not alone any more.
Old 06-07-2021, 08:48 PM   #3
bigskypc50's Avatar
Coachwork: AMTRAM
Chassis: INT
Rated Cap: Big Girl
LOL That SOB will get replaced right away.
Old 06-07-2021, 08:51 PM   #4
Any chance you could do a twofer?
Old 06-07-2021, 09:21 PM   #5
Check the blow by through the oil cap. Maybe someone else can confirm this, but while the engine is running, take the oil cap off and turn it upside down to get a little bit of an idea how the rings are, thus, an indicator of engine wear
Danjo is online now   Reply With Quote
Old 06-08-2021, 01:27 AM   #6
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
propane
yup I'd do it. IF that has been run on propane, it is difficult to ever get it running rich... means engines last longer than on gasoline. So, yea, possible never rebuilt. Has never needed it.... I would be curious to see what hot idle oil pressure is.... 10-12 lbs at 750 rpm or so and 35-40 ish at around 3,000 rpm. timing chain might be a bit floppy....
nice find for $1000
william
