Originally Posted by Nick5272
Demac, thanks again for the valuable input. It took me a second to follow what you were saying but to make sure I’m with you: you’re driving framing screws vertically up through the floor to put the framing pieces on? This is the first I’ve heard of a sill plate so that is not familiar to me.
I trust your knowledge and experience, but this method stood out to me since (as far as I’ve journeyed at least) you’re the only one I’ve seen do this. My knee jerk questions for ya are:
1. Do you not worry about mold or rot on the pieces that are touching the bare metal floor and have the screws from the exterior running up into them? Won’t they condensate and introduce moisture to the wood?
2. Won’t this create an incredibly difficult geometry to cut your subfloor pieces around? Besides protecting the subfloor itself, what other pros are there to this method?
3. Probably should’ve asked this first, but what are you doing for subfloor and insulation? Pink foam and plywood or something else?
I relate strongly to the wiping TP like a madman comment lol. Don’t feel like you’ve gotta answer all these either, this method just caught me off guard! Brand spanking new in my mind. Thanks!
Screws are not hypodermic. Condensation requires moist air and two temperatures.
Radiation, Convection &/or Conduction generates the temperature fluctuations.
Only the exterior facing screw heads are exposed & to a single air temperature. Sweaty head outside is the only possibility, but ought not, unless the interior lumber is icy cold.
Here in Hot, Wet, Florida, the condensation occurs, on single pane glass, OUTSIDE of cold AC homes.
For mold, mildew & moisture, I sealed the Building Envelope before installing any wood.
But also...
On the first morning, we applied exterior paint to
five sides the sill plate, drilled the steel & later attached the painted side down.
The following morning, I added two coats of exterior paint to the up-facing sides, then left the fans on it for a few hours.
The second 2x4, the Sole Plate, is attached to the first using 2-1/2" 9 Simpson SD Connector Screws & fender washers.
The top of the wall is attached in the same two-layer fashion.
Since sealing the shell, two years ago, I've not had any moist air or condensation. No mosquitoes, bugs or ants may enter. It's my every day farm shop. Even my 🎄 dries out overnight.
In my experience, that is how most buildings are built:
Dry roof, interior framing, mechanicals(HVAC, electric, plumbing), wrap & windows (dry-in), drywall, cabinets, paint and finally fixtures & finish floors (about the same time). Meanwhile, tools, sharp objects, leaks, spills & boots gravitate to one place, only.
