Old 12-26-2021, 09:56 PM   #1
Year: 2008
Chassis: Blue Bird Vision
Engine: 6.7 Cummins
Drivers Seat Belt Bracket on Ceiling
We have removed the ceiling from the rear all the way to the front driver’s seat. There is a bracket that holds the shoulder portion of the seatbelt from the ceiling. I don’t recognize the fasteners and I am not sure how to remove it or if I even should. I thought about cutting around it or removing it with a grinder and then reattach later after insulation and wood ceiling go in. I was hoping some of you could show what you did in your bus.
Thanks, Banjo Joe
C7E15083-F9D0-46F9-BA82-D6DDCFC737FC.jpg   DC6D4AFA-EE04-43E2-89F5-61EA8B7DABA1.jpg
Banjo Joe is offline   Reply With Quote
Old 12-30-2021, 09:44 PM   #2
Meathead's Avatar
Engine: 3126b 210hp
Rated Cap: 48
Hmmm. At first I thought those were Allen bolts but I don’t recognize either.
I would remove with vice grips or grind the bolts off. The important thing is that the bracket is bolted to a hat channel (rib). I’ll see if I can find a pic of mine.
Meathead is offline   Reply With Quote
Old 12-30-2021, 10:03 PM   #3
Meathead's Avatar
Engine: 3126b 210hp
Rated Cap: 48
Oh. My bracket is different but there are probably nuts back there. Made into (welded?) the hat channel. So if you grind em off you will still have to remove the bolts somehow.
Old 01-01-2022, 03:49 PM   #4
Year: 2008
Engine: 6.7 Cummins
I figured it out
I just cut around it with a cold chisel and will cover around it later with the ceiling.
Old 01-01-2022, 07:32 PM   #5
Meathead's Avatar
Engine: 3126b 210hp
Rated Cap: 48
[emoji106]
