Old 03-12-2019, 11:20 PM   #21
Dead pirate's Avatar
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
It had double rings. They we're all on their last leg. I redid everything.
Those are some great ideas. I'm Gonna look into them. I was contemplating an electric fan. That clutch fan is a terrible idea.
It was easy to rebuild tho. My first of something this big. Cummins 5.9 and the like before.
Dead pirate is offline   Reply With Quote
Old 03-13-2019, 12:07 AM   #22
Chassis: GA39530
Engine: DT466E 215hp 620tq
Rated Cap: 40
Updated Orings
Navistar updated the liner orings to a wide single oring that is orange. Thy specify using vegetable oil to install them as well since the vegetable oil will not swell the oring.
FamilyCircus is offline   Reply With Quote
Old 03-13-2019, 01:32 AM   #23
the 9 blade fan with the Horton clutch is a huge upgrade over the viscous clutch... I did it on m,y T-444E and the results are amazing.. you'll never begin to move enough air with an electric fan..
I thought the 4900 Radiator frames are much taller than the 4700s which are 3800s are based on.. and I think the FE busses are using the same size as the 3800s.
Be careful when shopping for fans and clutches, I believe the belt drives the back of the fan pulley on the 466E vs the front side like the mechanical or the T-444E which means you have a reverse rotating fan comoared to those other common engines..
ECCB has a later nodel IC/Amtran bus he recently sold to a friend of his.. it has a 466E and the full rad / CAC.. see if you can snag his VIN and get the rad / CAC part numbers from it.. my guess is those will fit your busses..
Old 03-19-2019, 03:58 PM   #24
Coachwork: myself
Chassis: amtran
I have it completly back together and one of the terminals on the starter is wonky. Now i have to pull the starter. What next?
