Hi!
I have a bus with the curved fiberglass panels. The panels were 90+% disconnected when I got it.. basically only held on by a handful of rusted off screws on the ends
The metal behind was filled with rust holes from leaks - I didn't realize it was possible to so poorly build a bus
Anyways, I'm wondering if anyone has ideas on what type of adhesive to use to reconnect the panels after getting the frame fixed up.
The paint store suggested I used the 3m panel epoxy, but as you can see in the pics (of the old adhesive) that sometimes the panel is tight against the metal, and sometimes there is a 1/4-1/2 inch gap filled by the stuff. Basically, the steel frame doesn't perfectly fit agains the panel, and the adhesive fills some gap.
Here's the epoxy adhesive:
https://www.amazon.com/3M-08115-Pane...s%2C168&sr=8-3
In this article:
https://www.assemblymag.com/articles...ailer-assembly
they used Loctite 5570 and H8600.
What do you think about the best adhesive for this?
Before:
Panel removed:
Inside the panel:
Close up of joints:
