Old 08-27-2021, 03:39 PM   #1
Finding correct Hitch Receiver for 2011 Chevy Express 4500
Working on finding the right hitch for my 2011 Chevy Express 4500 with Thomas body. Will any hitch that fits the same van body (example: 2011 Chevy Express 3500) also fit my Express 4500 bus?
Here's a Class 5 hitch that I found:
https://www.amazon.com/Draw-Tite-419.../dp/B009F59M64
Picture of bus once we paint it
rg1220 is offline   Reply With Quote
Old 08-27-2021, 09:13 PM   #2
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
Hitch... will it bolt on?
IF, thomas did not modify the frame rails, yes probably,
IF thomas cut the frame rails You might have to drill some holes, but will likely fit.
IF thomas added on to the frame, maybe, maybe not, depends how good they are.
william
Old 08-28-2021, 01:38 PM   #3
Great, thank you!
Old 08-28-2021, 01:50 PM   #4
Measure the frame width, the hitches will be for specific widths.
Old 09-02-2023, 06:14 PM   #5
Hitch question
We have the exact same bus. We are looking to add a hitch and was wondering what you ended up using and what you needed to do to install.
Deb F is offline   Reply With Quote
Old 09-02-2023, 08:50 PM   #6
This is the hitch I bought: https://www.amazon.com/gp/product/B0009XG9L2
It should fit with the existing holes in the frame rails, however, I did make some adjustments to the bus. I had to cut the steel bumper to let the receiver stick out. I also cut part of the flange that attaches the bumper to the frame. But I'd start with getting the hitch and seeing if it fits and what adjustments you might need to make.
Attached 2 pictures I took earlier this year.
Old 09-02-2023, 08:55 PM   #7
Great...thank you!
