So my bus is going to be set up a bit different than most. Mostly I am building a 'mobile ham-shack' and essentially will have a desk or two, some seats/couches/benches and some storage units (shelving mostly)
I am not really interested in chasing random leaks, have no plans to ditch the bus windows, etc.
With that said, I do want to replace the plywood flooring, mostly as the rubber puke mat is coming up in spots. Again, not wanting to find the few small leaks I have that seem to come in behind the dash (likely windshield) and under the drivers window, I am looking at an idea that would work around that.
I am thinking about painting the metal with a good rust proofing paint (rustoleum, or chassis saver), and then using the 'Dri-core' panels like this -
https://www.lowes.com/pd/DRIcore-Sub...ent/1000510831
On top, I was going to just put one big long continuous sheet of Linoleum.
The thought is, for the most part, any leak will sit on top of the linoluem, but if something does get beneath, it will sit in the space that the dricore creates, and will eventually (Maybe??) evaporate.
Looking for opinions on the concept here, and keep in mind, if my puke mat wasnt damaged, I would likely just leave it as is!
