Old 03-12-2019, 02:05 PM   #21
Rovobay's Avatar
Rated Cap: 35
Originally Posted by BlackJohn View Post
I did mine driver side ahead of the rear wheel so when I use that side view mirror I can see the state of the smoke happening during a cold start and while driving. Early detection for my mind of how the engine is performing at any time either cruising or pulling hard on grades.
I like to see anything but white smoke.
Agree picnic side could be a problem at times but hardly ever picnic with engine running. However, loading from the passenger side door may attract some fumes I'd rather not breathe when I'm idling.
My 2 cents,
John, I like that idea and was planning on doing the same if I decide to reroute my exhaust. since my bus is 3/4 size with smaller wheels, I don't have the luxury of large under belly storage options compared to my full size brethren. as I am still building I am still undecided about an indoor lav and the need for a black tank or not. either way, I will make my hookups all on the driverside which seems the industry standard as far as easy of hooking up to power, water, waste, etc.
My Build: https://www.skoolie.net/forums/f11/sk...doo-22140.html
Follow our build on Instagram at https://www.instagram.com/skoolie_doo/
Rovobay is offline   Reply With Quote
Old 03-12-2019, 02:36 PM   #22
Moving my exhaust afforded me the room to mount my black tank directly under the throne which worked out well for having that where it should be for campground dump facilities. I have room back there also for storage of electrical cord, hoses etc and firewood.
Hope yours turns out as you wish, good luck.
