RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 09-27-2020, 11:48 AM   #21
It makes no sense to have the tech screws threading into the wood. All that is going to do is cause the wood to lift as the screw tip hits the metal. Even if the screw does finally penetrate the metal there will still be space between the wood and metal and the wood will seem lose even with the screw head flush with the wood. To then get the wood tight will require the screw to strip out the threads in the wood so the screw can finally pull the wood to the metal. A hammer drill may help with this but since there is way more thread contact with the wood, either the screw threads themselves where they go through the metal or the metal itself are very likely to strip.
Drill a pilot hole of the proper size for the tech screw through both the wood and the metal and then enlarge the hole in the wood to a size that lets the tech screw drop freely to the metal through the wood. When actually tapping the metal with the tech screw use a drill speed just fast enough to allow for the tech screw to cut. Too fast a speed will suddenly bottom out the screw and either strip it or break off the head.
Old 09-27-2020, 11:59 AM   #22
Chassis: TC/2000
Engine: 5.9 Cummins 12-valve
Rated Cap: 1
Are you hitting the frame under the floor?
BamaBus is offline   Reply With Quote
Old 09-27-2020, 03:22 PM   #23
CHEESE_WAGON's Avatar
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Same thing I was saying, in addition to...
I think OP is experiencing a combination of these. I also think the screws are long enough that they are not able to sink the head completely into the wood.
"CHEESE WAGON" <anomaly.va@gmail.com>
Suggested reading: (4 threads)
Old 09-27-2020, 06:33 PM   #24
The Tek screws being used have wings after the tapping head. These wings cut a hole in the wood the size needed to allow the screw to burry itself without actually screwing the wood and lifting the wood when it hits the metal. These are wonderfully engineered screws ... the metal floors in the bus are wonderfully hard to cut and take a lot of pressure to cut the tap for the metal screw threads.
Old 09-27-2020, 07:28 PM   #25
threr are specific screws , heavy duty ,kinda like screw used to fasten boards
onto flatbed trucks ,check local resource truck co. or rental yard
gussboy is offline   Reply With Quote
Old 09-27-2020, 09:39 PM   #26
Chassis: TC/2000
Rated Cap: 1
I think you were right and that was the idea I was trying to reinforce without mucking it up with other thoughts. Seems to me that a 3" screw is way too long if just trying to screw down plywood to a metal floor. Either hitting the frame rail or something else to make it stop with 1 inch to go. I see it hitting the rail and it is actually wanting to push back up against the metal floor, but it can't and that's why the drill stops.
Old 09-27-2020, 09:58 PM   #27
Those screws have a 3:4” long pilot metal cutting bit on the front, then the screw starts. The wood-to-metal screw has a fine thread that can screw through wood, but then quickly strips out in the wood. The pilot bit in the front can *almost* make it through 1/8” mild steel. So when you buy those screws they need to be 1” longer than the material that you want to screw
Old 09-30-2020, 05:26 PM   #28
witchywoman's Avatar
Year: 2006
Rated Cap: 30
We got it! Last night I went and grabbed an impact driver. And today...voila! Screws went in and are seated perfectly. It was actually pretty simple nice we learned the tool we needed. Thanks everyone!
witchywoman is offline   Reply With Quote
Old 09-30-2020, 05:48 PM   #29
Year: 2006
Rated Cap: 30
We were screwing the plywood down on top of insulation so I allotted for leaving 1/2” on the underside of the bus. The 2 sheets we put down are sitting nice and firm.
Old 09-30-2020, 05:51 PM   #30
Excellent!!!
Old 09-30-2020, 06:05 PM   #31
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Originally Posted by witchywoman View Post
we got it! Last night i went and grabbed an impact driver. And today...voila! Screws went in and are seated perfectly. It was actually pretty simple nice we learned the tool we needed. Thanks everyone!
we were screwing the plywood down on top of
Old 09-30-2020, 06:45 PM   #32
s2mikon's Avatar
Engine: Cummins 8.3
Here is what I used. https://www.ebay.com/itm/50-1-4-20-X...AAAOSw4HVWEXMF
Pre-drill 3/16 and use a t-30 torx bit on a electric impact gun. I used about 300 of them. I have no monetary interest in the evil-bay seller.
s2mikon is offline   Reply With Quote
Old 09-30-2020, 07:13 PM   #33
I won’t use anything else now
After a lot of money and trial and error this is what I’m using. PowerPro One Multi-Material by Hillman. Lowe’s carries this in stock. Pre-drill and you should be fine.
File Type: jpeg C318B993-57F8-4D2E-885A-08016EAE80B4.jpeg (110.5 KB, 3 views)
File Type: jpeg F7F7CCD4-622A-4902-B38D-80C8C931F97E.jpeg (83.6 KB, 7 views)
Rubicon58 is offline   Reply With Quote
Old 10-02-2020, 08:43 PM   #34
screws ,wood into metal
bypass useless opinions ,here the straight dope ,me retired builder .
have worked on mobile homes trailers, what exactly is dimension in
thikeness of woo ,and metal below?
And is metal below 1/8 inch sheet metal oir are you drillin into frame rails
you must use proper fastener , Fastech .com
use a screw that is made for wood on top metal below of sufficent
length to go through wood {passing thru.pullin down}
and of proper diameter ,to thread into sheet metal /NOT STRIP OUT.
also sometime must use pilot srew hole {metal BIT} 1/8 smaller then screw size
Also buy a dewalt brushless impact driver .you need the power to
do the work
the screws shown on your post are average deck screw NOT good enuf.
I hope this help gussboy ,see my bus#10 crown
Old 10-02-2020, 09:19 PM   #35
Please refrain from your insults
I have built homes and rebuilt cars for over 40 years. The fastener I’m using in my Skoolie is an awesome fastened. I doubt you have used this fastener for anything to please refrain from your insults. Thank you.
File Type: jpeg E655C7DA-3F0C-4D73-B1D5-BB1FBD932CF2.jpeg (51.0 KB, 3 views)
Old 10-02-2020, 09:29 PM   #36
sorry if you feel insulted ,ive got ,nothing to add
Old 10-02-2020, 09:30 PM   #37
Whatever, dude.
Old 10-02-2020, 10:09 PM   #38
I don't think the other user meant you specifically with their "bypass useless opinions". I think they were referring to everyone else here with an opinion. One feature of skoolie.net that can really improve the experience on this forum is the ignore list. Click on User CP in the upper left and then click on "edit ignore list". You can then add users to the list and their posts are automatically hidden from you.
Old 10-02-2020, 10:45 PM   #39
Thank you
Thank you for the heads up. I will do that.
Old 10-02-2020, 11:52 PM   #40
the screw a very experienced person is showing is not a flush finish bugle head screw
do you think a flat smooth surface is good for a floor
me 50 years exp.
