RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 04-28-2020, 03:54 PM   #1
Chassis: S-1800
Engine: NAVSTAR DT 466
Rated Cap: 49
Got my floor in!
I’m 6’1” so couldn’t go with lots of insulation on the floor. I welded 127 holes, painted with rust preventative. Then put 1/2” rigid insulation down, and covered with 3/4-7/8” oak. It’s rustic, but this is my moving van and home, so will need ruggedness first. Old oak= rugged, and tho not an insulator per se,, it’ll retain temps, and I’m not going north...
File Type: jpeg 4C2838D1-18A6-4DAA-9C0F-B0E4D401E29C.jpeg (132.4 KB, 16 views)
YankeeDespot is offline   Reply With Quote
Old 04-28-2020, 05:18 PM   #2
They are so nice! I'm going to be using Vinyl on mine I'm pretty sure, haven't decided on plank or sheet yet. Might go with sheet vinyl for ease sake. Can't wait to see the rest of your build
2ndMonday is offline   Reply With Quote
Old 04-28-2020, 05:56 PM   #3
Where did you get your oak? I was trying to find oak 2x4s (1.5" x 3.5") to use in my floor rebuild because of their greater resistance to bending than pine (about 15%) but oak is so damned expensive and I couldn't find anything thicker than 1" or 1.25".
Old 04-28-2020, 07:23 PM   #4
That’s a nice looking floor
Old 04-29-2020, 11:47 AM   #5
Chassis: S-1800
Rated Cap: 49
I got a load for free, but had to run through planer/ jointer and that took a while. Not sure where u live, but in VA CP Johnson is a great source. Check local Craigslist , but it’ll require some luck. Good luck!
Old 04-29-2020, 11:48 AM   #6
Chassis: S-1800
Rated Cap: 49
Also, 3/4” oak is crazy strong and heavy. If you handle a 1.5” thick oak board, you may agree that it’s overkill.
Old 04-29-2020, 11:49 AM   #7
Chassis: S-1800
Rated Cap: 49
Thanks! This is fun!
