Old 12-07-2020, 10:20 PM   #1
Ground clearance, wheelbase and departure angle
Hey all,
Was hoping someone could give me some general info on a dog nose. I'm looking to see if I can park a schoolie behind my house because of my steep 22% 75' long driveway. It's surveyed and in CAD, what I need is a rough side view diagram of a dog nose to make a "virtual" bus I can check to see if the back will bottom out going up at the bottom or the middle will high center on the upper vertical curve.
I was hoping for a 36ish foot bus. I know it'll change from bus to bus, just hoping for rough numbers of an example to see if it's somewhat doable. If I'm close I don't mind working the driveway vertical curves to get me the rest of the way or putting planks down ect
Shea_G is offline   Reply With Quote
Old 12-08-2020, 01:12 AM   #2
Just pick a bus model and look at pics of them to estimate it. School Buses sit up pretty high, but some have rather long rear overhangs.
You need the power to climb that grade as well.
Old 12-08-2020, 10:17 AM   #3
Chassis: G30~Chevy cutaway
Engine: 5.7/350 Chevy Vortec
Hope you don't live anywhere that temps drop below freezing, as a light coating of ice on a 22% grade would pose problems for even a 4x4 to ascend!
Old 12-08-2020, 11:04 AM   #4
Ronnie's Avatar
Engine: 345 international V-8
I can measure the departure angle on a bluebird we have here. It is a 34ft 11 window dog nose.
Old 12-08-2020, 11:10 AM   #5
you also need something that is geared low enough that you dont stall the transmission on the way up.. 22% is a LOT of grade for a many 1000s pound bus .. diesels have a lot of low end torque but it is possible to stall the torque converter to where essentially the bus wont move because it cant make the torque to lift the weight.. esp if there is any resistance like its a dirt or gravel driveway..
Old 12-08-2020, 11:42 AM   #6
Chassis: Vista 3600
Rated Cap: 24000 lbs
this is where, and likely the only time lol, that I would say NOT to buy a Vista
we are pretty low profile
front is very low, arse is high
yet inside is level
it's a bit odd like the Tardis in this way
but I am waay limbo low in the front clearance area
RolesvilleMarina is offline   Reply With Quote
Old 12-08-2020, 12:00 PM   #7
Ronnie's Avatar
In the 4x4 world crawl ratio is what gets attention. With low range and a very low 1st gear it is a very slow walk, great for pulling steep grades. Thing is most buses do not have that.
Old 12-08-2020, 12:01 PM   #8
Coachwork: Blueburd
Chassis: International S1800
Engine: 9.0L International Diesel NA
37 ft dognose
Feel free to steal the photo from instagram if it helps. I can pull dims over the weekend. Send me a pm if you need more
Rochey6957 is offline   Reply With Quote
Old 12-08-2020, 12:27 PM   #9
Ronnie's Avatar
34 bluebird 10x 22.5 tires, 11ft from center of axle to bumper, 14 degree departure angle.
6 window Amtran (international) 22.5 low profile tires. 7ft from center of axle to bumper, 18degree departure angle.
The shorty might be close if it had 10x 22.5 or even 11x22.5 tires. Both buses have rear exhaust that would have to be re routed to allow the angle measured. Neither bus has "crawl" gears.
Army deuce and a half? that would do it. Or unimog
Old 12-08-2020, 06:56 PM   #10
Meathead's Avatar
Engine: 3126b 210hp
Rated Cap: 48
Just get a running start at it! (Driveway)
And donít worry about those sparks!
Peace!
Meathead is offline   Reply With Quote
Old 12-11-2020, 08:02 AM   #11
Thanks a ton, any idea on the ground clearance on those in between the axles (the most likely place it would high center cresting a peak)
Old 12-11-2020, 08:08 AM   #12
As far as the hill climb and ice goes, it would be a once a year climb in spring and I was thinking worst case I go slow, and use my truck and a tow rope to give it a little extra assisted pull going up. Thanks for all the replies btw, I sent you a pm Ronnie.
Old 12-12-2020, 07:36 PM   #13
Ronnie's Avatar
Ground clearance in the middle is about the same angle and distance. Do not see a pm?
Old 12-12-2020, 08:34 PM   #14
Originally Posted by Shea_G View Post
Hey all,
I posted a set of departure angle diagrams for Thomas buses on this thread:
https://www.skoolie.net/forums/f33/t...les-31264.html
Cheers!
Old 12-17-2020, 07:01 PM   #15
Year: 97
Engine: T444e
Rated Cap: 25,500
ground clearance
Not counting ice and traction and power issues, what really matters for ground clearance is the transition distance from flat to 22 deg. A long slow ramp will have more room for clearance than a short one. A surveyor's level and a tape measure will tell.
Studedude is offline   Reply With Quote
Old 12-17-2020, 07:28 PM   #16
Do you plan to work on the bus while it's parked like this? Moving around inside would be pretty difficult at that angle. I'll never complain about my one-foot drop again if you are.
Old 12-17-2020, 07:41 PM   #17
My bus is a typical 35-footer. I think the angle of the green line from the bottom of the rear tire to the bottom of the bumper is maybe 6 degrees / 10% grade (?) but for sure a lot less than 22%.
