Hanging things off of the frame...
Whether I weld, bolt or strap things to the frame...
Should I avoid putting weight on the transverse horizontal members which directly support the OEM floor?
I presume the middle third of the depth of the main longitudinal frame member may be drilled into, threaded, and bolted to?
If not threaded per that, then drilled through and through bolted to, as with varied lengths of all thread? (which should be stainless steel; all holes to be gasketed/sealed to prevent moisture intrusion? )
As long I am am adding weight below the floor on average compared to above the floor, and not going ever the "with full tanks" gross vehicle weight, I am improving the center of gravity?
Something I intend to hang off of the frame are epoxy coated and glass/kevlar reinforced DIY tanks for fresh/grey/black water. I should count on metal lining the exterior of those to prevent thrown gravel/rock damage? I already plan on insulating them with foam/adding heat strips to preclude freezing.
Bus is a 37' Saf-T-Liner Thomas, if it makes difference.
