Old 09-24-2020, 03:00 PM   #1
Chassis: Blue Bird
Hat Channel Gauge?
What gauge steel did you use for your hat channel? I've been calling metal fabricators to get a quote on making me hat channels. I got this quote today;
For 32 pieces 18" long, formed to a Hat Channel;
Option 1- 14 ga mild steel $446.65
Option 2- 14 ga. Galvanized $515.20
Do the new hat channels need to be the same gauge as the old to line up correctly? What gauge did you use in your hat channels? Thank you for your time.
MorningOwl is offline   Reply With Quote
Old 09-24-2020, 07:10 PM   #2
Coachwork: 44' Newell Coach
Engine: 8v92T Detroit
Rated Cap: 2 adults and two pigeons
Curious as I am in the same boat. I was thinking the channels were 12 gauge on my 2003 BB All American
--Simon
Bus'n it is offline   Reply With Quote
Old 12-07-2020, 06:06 PM   #3
I wouldn't go any thinner than OEM. I have no math or experience to back this up but it just makes sense.
I'm in the process of raising my roof also (planning) and I'm more concerned with how much overlap should be accounted for. I'm planning on overlapping the custom hat channel inserts to overlap the OEM inserts by at least 6 inches on either side of the cut.
Thong Ranger is offline   Reply With Quote
Old 03-26-2023, 08:43 PM   #4
Chassis: VIN = 1T7HR3B2311090770
Rated Cap: ~72
A quick look at other threads
Suggests 14ga to 13ga and for how you are using it suggest 1"x2" or better 1 1/2" x 2".
TaliaDPerkins is offline   Reply With Quote
