Old 02-17-2020, 02:18 PM   #1
Chassis: FS-65
Engine: Mercedes-Benz MBE 900
Help, removing hydraulic lift!
We hit a spark and not in a good way in the process of removing our hydraulic handicap lift. The red wire with the metal cap grazed a metal part of our bus and sparks flew. Everyone is fine but we want to move forward safely. Any advice?
EE15A1ED-8AB3-401D-A980-9130DD65FCD0.jpg   09ADF902-8DC8-4876-898D-B994FB2FC579.jpg   F5CEF711-16F1-46F7-909E-FF3D6D1C0EAF.jpg
AlexVega360 is offline   Reply With Quote
Old 02-17-2020, 02:26 PM   #2
Do you have a voltmeter you can test for voltage? If you do, you can see if it’s still live.
Put a bunch of electrical tape on that terminal end
Remove the negative terminal from the starter battery/batteries and make sure you have no power.
Trace that cable back to where it starts, probably under the hood. Disconnect it and then remove the cable.
Old 02-17-2020, 03:48 PM   #3
That positive lead runs to the positive side of your battery(s). Unhook it from the batteries before doing anything with the lift. The lift is grounded to the bus.
I left that lead in case I ever want to run anything powerful in the rear of the bus right off the batteries.
No need to unhook anything from the starter unless that lead runs to the starter but it doesn't it runs off the battery.
Old 02-17-2020, 04:19 PM   #4
Chassis: FS-65
Thank you so much EastCoastCB, is it okay to just put the plastic case back on and get to work on it tomorrow? My husbands a bit worried about more sparks and a fire hazard.
Old 02-17-2020, 04:50 PM   #5
Yeah, just don't let the end of the big red lead touch metal on the bus.
If you open up your battery tray you'll likely see it connected. Follow it to make sure.
Old 02-17-2020, 05:00 PM   #6
Chassis: FS-65
Awesome, thank you so much! We really appreciate the quick reply.
Old 02-17-2020, 05:08 PM   #7
No problem.
Did you already unbolt the lift?
I've had a much easier time lowering the lift and taking the pins out of the arms to remove it. They come off quick. I cut the lines and chuck it all to the curb.
Old 02-18-2020, 02:23 AM   #8
No problem.
Thanks for the tip. I’ve been wondering how I’m going to drop it single-handed
Old 02-18-2020, 07:25 AM   #9
matthews2001's Avatar
Coachwork: Thomas Bus
Chassis: Allison MD 3060
Engine: Catepillar 3126B 210hp/605 ft lb
I sold mine on ebay, $400, took a while cause they had to pick it up, hard (nor impossible) to ship.
Used the 12vdc wire for my inverter. It went to a relay and switch on the dash
matthews2001 is offline   Reply With Quote
Old 02-18-2020, 07:34 AM   #10
Dang, I'd sure love to get $400.
I've tried giving them away and had no luck.
Old 02-18-2020, 03:56 PM   #11
Chassis: FS-65
We did, but we'll put some work into it this week. Probably get it out to the dump soon. What did you end up doing with yours?
Old 02-18-2020, 05:38 PM   #12
peakbus's Avatar
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
i just sold a second one for $250 on Craigslist. The buyers backed their pickup up to the wheelchair door and we slid it right in.
peakbus is offline   Reply With Quote
Old 02-18-2020, 09:38 PM   #13
Dragged it out to the road and eventually some scrappers came and got it.
What part of central FL are you in?
Old 02-19-2020, 05:30 AM   #14
Chassis: FS-65
Deltona area, the dump isn't too far here in Volusia County. We've done some downsizing so the neighbors are used to seeing stuff out every once in awhile.
Old 02-19-2020, 06:10 AM   #15
thankfully since most bus refuse is steel the scappers have kept me from ever having to use the dump.
You should come over some afternoon. We could talk buses. I'm in the Eustis/Sorrento area.
Old 02-19-2020, 04:43 PM   #16
Chassis: FS-65
We would love that, we'll keep you posted on how the lift works out. Hoping to put some hours in before the weekend and make some more progress.
Old 02-26-2020, 04:29 PM   #17
For that large red power wire, slide a length of hose over it to insulate it. You may want to tape it with electrical tape to keep the hose affixed.
Tim in Burien
Btimmer is offline   Reply With Quote
Old 02-26-2020, 04:59 PM   #18
Year: 2011
Coachwork: International IC
Engine: Maxxforce7 diesel
Rated Cap: 17500
On our bus we had a 109amp breaker that we simply shut off. It was attached to the wall of the battery box. We cut our red cord before it entered the bus at the back and bugged the end off. We also then made sure that the underside of the bus would never come in contact with the end even though it was taped, protected and taped again. When we want to use that power, we can turn the breaker back on. We’ll have to figure out what we want to power first.
6windowsNadream is offline   Reply With Quote
Old 02-26-2020, 08:38 PM   #19
FYI
When ever working with electric such as this your best bet is to always disconnect the negative cable at the battery or batteries first. Then if you happen to touch something that is on the positive side of circuits it won't arc. Then always hook up the ground cables at the battery last.
You can get a cheap voltmeter at any hardware store or even a test light if you need to check for power.
Popper
popper is offline   Reply With Quote
Old 02-27-2020, 05:34 AM   #20
Coachwork: Ic ce Navistar international
Chassis: Ce 300 school bus
Engine: 7.6L international ic ce 300 school bus
Disconnect the battery power before proceeding
Sp6saz is offline   Reply With Quote
