04-07-2021, 10:56 AM
Chassis: International RE
Engine: International T444e
Rated Cap: 76
Help with Rustoleum scratching?
Hey all, I'm working on the solar slideout system for the roof. I'm using Rustoleum High Performance Protective Enamel, Oil Based. Day two after the paint has dried I can still easily scratch the paint with anything, even with my fingers.
My process so far:
- Cutting metal to length
- Taking the rust off with a wire brush
- Thoroughly cleaning off any oil residue using degreaser
- Power wash
- Dry
- Rustoleum Primer, two coats
- Rustoleum White enamel, two coats
What am I doing wrong?
04-07-2021, 11:24 AM
Rated Cap: 48 passenger
That seems like typical results. I love rustoleum but one of the drawbacks is it takes weeks to get that durable enamel hardness. I've seen people put a hardener additive in it but not sure how much of a difference it makes.
I think rustoleum takes exceptionally long before it gains its durability, though I don't think any high gloss single part paint will gain hardness quickly. 2 part automotive paints and epoxies gain their hardness quickly but come with several tradeoffs...
04-07-2021, 11:25 AM
Rustoleum is a solvent-based paint. You probably just need more time
04-07-2021, 11:32 AM
My process so far:
- Power wash
- Dry
I've found rusto takes at least a month to get to full hardness - before that it's easy to scratch.
04-07-2021, 11:39 AM
What Musigenesis said. Absolutely !!
04-07-2021, 11:46 AM
Rated Cap: 76
Thanks guys, if that's the case so be it, just as long as I wasn't screwing it up somehow.
04-07-2021, 02:20 PM
Chassis: Ford E450
Engine: V10 Gas
Enamel paint first dries (loses the solvent), then cures. Curing is an oxidation process and takes 2-4 weeks, longer if the paint is thicker.
I think the lakes and ponds in New Hampshire are still in ice-out! You need low humidity and 70 degree temps for fastest cure time.
04-07-2021, 02:22 PM
Rated Cap: 76
Currently in KY.
04-07-2021, 02:39 PM
Year: 2005
Chassis: RE300
Rated Cap: 30 + 2 WC
Rustoleum and hardener
I am one of those who used the hardener with my Rustoleum paint job. The paint could resist at least my fingernail after 2 days, although it may have still be setting up afterwards. This is what I used, just following the instructions:
https://www.tractorsupply.com/tsc/pr...t?cm_vc=-10005
