Old 07-08-2020, 11:35 AM   #1
Sraycwb's Avatar
Coachwork: International 3800
Help with window by door please
Have removed all windows down passenger side except for the last which is located next to the entry door.
The problem is the tray located under and around the opening mechanism is in the way.
Here's a YouTube video of my problem:
https://youtu.be/5UA4iyXVayU
Which shows more accurately my issue.
Suggestions on how I can overcome?
Thank you!
Sraycwb is offline   Reply With Quote
Old 07-08-2020, 11:45 AM   #2
you turned off comments on the video.
Try removing the fasteners that hold that end of the tray and make a little room to pull the window out.
Old 07-08-2020, 12:12 PM   #3
Sraycwb's Avatar
Roger that. Got it solved with the back 4 screws which went up on the outer edge of the door gasket as shown in video. Sometimes the solution staring you in the face is easiest.
Thanks!
Video: https://youtu.be/dlSf4QMBkkk
Course, here comes the rain.
Old 07-08-2020, 12:30 PM   #4
we got a heavy downpour this morning.
