Old 10-01-2017, 06:35 AM   #21
rossfree's Avatar
Coachwork: Chevy
Chassis: Ward?
Engine: 8.2 liter ?
Rated Cap: 24 Passenger
I started by caulking the holes. That didn't work so good. Then I used pieces of window screen and caulked them up. Better but time consuming and left a bump on the floor. Finally wisened up and used the bondo with glass. Happy camper. Fast and sandable. Easy to do a bunch in a short time.
Ross
rossfree is offline   Reply With Quote
Old 10-10-2017, 10:26 AM   #22
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
I put seamsealer on the bolt shank & drove the bolts back in the holes then covered the floor with 2" foam insulation.
Old 10-10-2017, 06:33 PM   #23
Oddball's Avatar
Engine: Cat 7.2 C7 I6 Turbo
Rated Cap: 66 ankle biters
The guy that tore up my floor used Liquid Nails to fill in the holes (after cleaning the surface). He then glued the plywood to the floor and caulked the sides.
Oddball is offline   Reply With Quote
Old 10-18-2017, 10:39 AM   #24
I also used the Fiberglass on my floor and ended up loving it. If anyone else is debating what to use, I would recommend it.
Lockeed is offline   Reply With Quote
Old 10-20-2017, 02:17 PM   #25
Daveyd007's Avatar
Chassis: BlueBird
I sanded then painted the floor with a first coat of Rustoleum white. Afterwards, I took aluminum HVAC tape and cut it into small squares to tape over the holes in the floor, then did a second coat of paint over the entire floor hiding the tape. Laid down 1/8" inch aluminum backed styrofoam with spray adhesive, then topped it off by bolting a new layer of plywood to the sheet metal floor.
Daveyd007 is offline   Reply With Quote
Old 10-20-2017, 08:33 PM   #26
Weld'em!!!
Old 10-21-2017, 06:41 AM   #27
Engine: 8.3 Cummins, 643
I used galvanized roofing caps and NP1 I'll probably do something similar on this bus when I get there. Welding would be the best but the underside of the weld should be painted after to prevent corrosion. My current bus has an undercoat to prevent rust which appears to have mostly worked. I wouldn't want to burn to much off.
Jacob is offline   Reply With Quote
Old 12-10-2017, 04:06 PM   #28
golfersmurf57's Avatar
Here's a thought most are 5/16 or 3/8 . large headed pop rivet with tip dipped in silicone and popped in wet
Sent from my LGL64VL using Tapatalk
golfersmurf57 is offline   Reply With Quote
Old 12-10-2017, 04:26 PM   #29
Chassis: Saf-T-Liner MVP ER
Epoxy and pennies.
Steve Bracken
Build Thread
Old 12-14-2020, 05:57 PM   #30
Engine: 5.9L 24V-L6 Cummins
Rated Cap: 37'
Originally Posted by tobeamiss View Post
That's awesome. I haven't put my flooring in yet...It's been a year now of stepping all over them everyday and those plugs are tough.
I really like the Henry's crystal clear 212 and find I'm using it alot during my build. But also, all I do is plug up the tube with a screwdriver...can pick it up to use it a couple weeks later and it's not clogged and good to go. I also use it as glue for the felt strips I put around the windows when insulating. And... I fill in all gaps where water might enter around the window. And...I run a fat line of it along the bottom edge of the windowsill before replacing the windows.
It's good stuff. If you make a mistake, wait for it to set and peel it off easily.
I can't say enough good things about it and the many ways I've used it. I might even name my bus Henry when I'm all through LOL
Hello Tobeamiss -
Super helpful to read everyone;s methods for water prevention! Using Henry's, how are your windows holding up 4 years later?
Sevier is offline   Reply With Quote
Old 01-23-2021, 10:38 AM   #31
tobeamiss's Avatar
Originally Posted by Sevier View Post
Hello Tobeamiss -
So far so good but I hate to jinx myself!
oh yes she did!
https://www.skoolie.net/forums/f11/to...-it-16557.html
Old 01-23-2021, 10:41 AM   #32
tobeamiss's Avatar
and, sorry it took so long to reply..... you know, holidays and life...... ;D
oh yes she did!
Old 03-04-2021, 08:32 PM   #33
Engine: dt466e
Originally Posted by bstewrat3 View Post
I used 3M Dynatron 550 seam sealer to fill mine. The Bondo products aren't waterproof so you will have to get underneath and coat them to keep them from absorbing water.
Holding up pretty good? Thinking of going this route
adic27 is offline   Reply With Quote
Old 03-06-2021, 11:17 PM   #34
Engine: dt466e
You used just that one product?
