01-30-2020, 08:07 AM
#21
Chassis: PB 105
Rated Cap: 37
Yes we were hoping for a deal but ended up at about fair auction value from what I've learned from y'all. Very glad I made this post, everyone here helped us to make the decision that this was our bus. Here's a link to a few unorganized pictures for now!
http://imgur.com/gallery/Acii60C
01-30-2020, 08:16 AM
#22
Looks really good!
Does your transmission have ll 6 gears unlocked?
01-30-2020, 09:00 AM
#23
Engine: 8.3 Cummins ISC
Rated Cap: 75
DT466E 's are more common in IC shorties after 04 since the T44E was discontinued at that point.
I would take an 2005-2007 DT466 if it was in nice enough shape and low miles. They have a decent rep for emission-era engines. Small EGR cooler that can be plugged or deleted without too much trouble.
Found a few threads on trucking forums where the box truck guys were able to delete their 05-07 DT466E's.
01-30-2020, 09:31 AM
#24
DT's in shorties aren't uncommon for any year range. The VT365 was ushered in to replace the 444.
01-30-2020, 09:38 AM
#25
Nice lookin' bus. If you have room to store it, I highly doubt you'll mind having more time to start thinking and building!
(And remember, you didn't have the added expense of flying to OR and driving it back...)
Is the wheelchair lift an added bonus (loading tools/toys?) or something you'll have to remove?
01-30-2020, 09:41 AM
#26
Rated Cap: 75
True, but it seems like IC didn't sell nearly as many VT365's as they did DT466s after the T444E was gone.
Those pushers with the WC lift in the middle are odd. Don't see them very often and it defenitely makes for an interesting floor plan if you plan on using it for a motorcycle lift or garage area.
01-30-2020, 10:55 AM
#27
Chassis: PB 105
Rated Cap: 37
Date code the trans was 01/06 so from what I've gathered I will not be able to flash it.
01-30-2020, 11:02 AM
#28
Chassis: PB 105
Rated Cap: 37
Yes there where 6-7 other buses up from the same district all IC mix of midsized and full sized, all with DT466. Most where Maxxforce's and in rough same compared to ours.
Ya I've read a lot of mix things on the egr delete if it's worth it etc....mostly from truck or diesel truck forums. Seems like they they don't cause much of an issue. Luckily this bus dated 07 was put into service March 1st 06. So there is no DPF which I've learned is when the issues seem to really start with the last of the DT's.
01-30-2020, 11:05 AM
#29
Rated Cap: 75
Yeah, I would avoid all "Maxxforce" branded DT466Es. I think those started coming out around 2008 or 2009.
01-30-2020, 11:07 AM
#30
Chassis: PB 105
Rated Cap: 37
The wheel chair lift was actually just serviced as well and is actually located 14 in forward from the rear wall of the bus... Considering the condition, we are actively trying to come up with a way to utilize it.
01-30-2020, 11:54 AM
#31
It looks like it's in the perfect spot if part of your build was a "garage space" for heavy items.
01-30-2020, 12:09 PM
#32
I read this morning that Navistar just agreed to a $137 million settlement to compensate the victims of the Maxxforce engines.
01-30-2020, 01:22 PM
#33
Rated Cap: 75
And that's why Cummins is now the only diesel option on IC buses.
01-30-2020, 01:40 PM
#34
Chassis: PB 105
Rated Cap: 37
Lmao ya you know you fucked when you loose an account like that....
01-30-2020, 02:17 PM
#35
Looks like the swear filter may be fucked!
01-30-2020, 02:32 PM
#36
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
Go away. 'Baitin.
Our Build: Mr. Beefy
01-30-2020, 03:11 PM
#37
Navistar is IC Bus. You're extra ****** when the account you lose is yourself.
01-30-2020, 03:13 PM
#38
Chassis: PB 105
Rated Cap: 37
Oh lawdyyyyy
02-27-2020, 09:54 AM
#39
Chassis: PB 105
Rated Cap: 37
With a ceiling height of 6'6" you should also have windows that are 29" tall (the low ceiling buses usually have 23" tall windows). Which is awesome if you're planning to keep all the windows. If you'll be getting rid of the windows, I would like to buy a few (one of my windows is cracked thanks to some complete moron stepping on it while it was flat on the floor).
Also, if you click on User CP in the upper left you can edit your details so that people on the forum know where on the planet you are and what kind of bus you have. Helps other users tailor their answers and advice.
Just wanted to let you know bus is being Gutted all of the windows look great, and will be ready soon for anyone interested in them.
02-27-2020, 11:09 AM
#40
I definitely want one, but I'm worried that the shipping would be astronomical.
