Old 12-12-2020, 08:59 AM   #21
Originally Posted by Sevier View Post
Do you remember what sealant brand/type you used for the windows? And did you have to seal the screw holes (for example, by putting epoxy on the screw before screwing it in)?
No, the screws I'm talking about are on the inside and don't need sealant (they're the screws with the big round washers around them that hold in both adjacent windows).
I use Dynatron-550 for sealant and highly recommend it. Cheapest place for single tubes is Autozone ($15 ea.) or you can get cases of 12 for $150 or so (you will probably use that much and more - I'm easily over 20 tubes already).
musigenesis is online now   Reply With Quote
Old 12-12-2020, 06:35 PM   #22
Engine: 5.9L 24V-L6 Cummins
Rated Cap: 37'
Okay, so bus window anatomy is:
Where window meets the bus - bottom
Where window meets the bus - two sides
Corners that seem to have large gaps where water comes in
Edges of the outer sill
Gaskets
So, what do you think of this procedure:
Where window meets the bus - bottom: Butyl tape
Where window meets the bus - two sides: Dynatron-550
Corners that seem to have large gaps where water comes in: Dynatron-550
Edges of the outer sill: Dynatron-550
Gaskets: Dynatron-550
Or .... Ive seen others suggest 3M OEM grade automotive seam sealer or 3M urethane sealer for the corners and vertical ??
Sevier is offline   Reply With Quote
How do I remove the windows from the front door of my bus? dogfinn Conversion General Discussions 20 08-23-2019 10:09 PM
how to remove sidepanels ???? swinada Conversion General Discussions 4 06-05-2018 06:44 AM
Remove or Not to Remove - Rubber Floor... usmcbay Conversion General Discussions 29 01-14-2017 05:44 PM
How to remove rear windows - Bluebird White99z Conversion General Discussions 7 07-26-2016 02:41 PM
Screening original windows and installing RV windows skoolz out Conversion Tutorials and How-to's 3 10-27-2010 01:54 PM
