Old 06-09-2021, 07:22 PM   #21
Year: 2005
Coachwork: MidBus
Chassis: Chevy Express 3500
Engine: 6.0 Vortec V8 Gas
Originally Posted by Danjo View Post
I used the PPG Delfleet Essential product line.
I used
Epoxy Primer ESU481 4:1
Hardener ESU489
Delfleet Essentials ESS 6:1:1
Hardener ESH200
Activator ESX 510
It was sprayed using HVLP sprayer, wet on wet. I don’t know about rolling. It’s possible that a foam roller would work, but I’d get a small amount and test it first. If I were to try rolling, I’d use a foam roller and avoid bubbles by trying to flush the air out of it by pushing it against the bottom of the rolling pan.
Great info, thanks so much! Hearing that others have had success with your method makes me feel great about it. Turns out we have a friend who paints houses who is going to do it for us. He has all the equipment including a tent to spray it in. Now that I know what paint to use I'm off to the store, then to his driveway!
Anonybus is offline   Reply With Quote
Old 06-09-2021, 08:35 PM   #22
While on the subject because Jack brought it up, I painted at OEM paint booth rental in East LA, great bunch of guys work there.
Anyway, they had Euro HVLP sprayers and it worked well, but before that, I used a purple Harbor Freight sprayer to spray rub rail with primer and it worked great too. I’ve read you can get a couple good paint jobs out of one of those.
Just wanted to plug OEM paint booth rental and the one good thing HF sells
