Old 02-28-2020, 11:35 AM   #1
Chassis: Thomas Built Chevy
Engine: 8.2L Detroit Diesel
How to remove panels with stuck screws
I am currently attempting to gut my bus; however, the 30 year old panels, attached with screws, are giving me a lot of trouble.
I can get about a third of them out with my impact driver, but the rest won't budge and end up just stripping out. I am thinking maybe an angle grinder can just cut the heads off. Is this my best route?
I have tried screw extractors as well with no luck.
bigbeanbus is offline   Reply With Quote
Old 02-28-2020, 11:41 AM   #2
ewo1's Avatar
Try using an S2 bit instead of a phillip's bit.
The phillip bit will strip the screw while the S2 will hold on much better.
for the ones that won't budge, hit them hard with a hammer first to try to dislodge them.
ewo1 is online now   Reply With Quote
Old 02-28-2020, 11:44 AM   #3
Grinder will work if you don't care about hitting the panels.
Harbor Freight has a decent set of left hand twist drill bits.
Use those to drill the heads off -- usually the heat of drilling coupled with the reverse rotation of the bit takes the screw out long before the head is completely drilled away...
David
The Murder Bus
Old 02-28-2020, 11:47 AM   #4
That's a good point!
My Thomas bus looks like it has phillips head screws but they are in fact "posi-drive" with a distinct sq opening in their center.
David
The Murder Bus
Old 02-28-2020, 12:05 PM   #5
mmoore6856's Avatar
Chassis: chevy
Engine: 3116 catapillar
before you try to remove any screw that is rusted in take a dull chisel and tap the screw sideways on 3 or 4 sides firmly but not hard enough to knock it off MOST times it will come off with no effort. i been using this method for years. i learned it from a modet t mechanic just before he retired. he knew a lot of tricks i never seen in mechanics school
mmoore6856 is offline   Reply With Quote
Old 02-28-2020, 02:26 PM   #6
Just smack the head with a hammer, it'll break free the rust connection.
Old 02-28-2020, 06:45 PM   #7
I've stripped out numerous screws on my bus. Generally, I just take an angle grinder with a cutting wheel and cut a notch through the head, then use a big regular screwdriver to turn it and get it out. This is a lot easier (and less destructive to the panel) then trying to grind or cut the whole head off.
Old 02-28-2020, 06:57 PM   #8
Year: 2006
Chassis: Safe-t-liner ef
Rated Cap: 54 passenger
They make a impact you hit with a hammer also that I have used on Phillips that were sealed on my Suzuki samurai to pull the door hinges off. It was the only way they would come loose they work really well to break stuff loose.
Nbigger is offline   Reply With Quote
Old 02-28-2020, 09:21 PM   #9
Member
All good suggestions here. I found that if the screw didn't budge after one or two hits from the impact - I reversed the driver and tightened it a few hits. Then it would reverse right out.
Also, what musigenesis said works a treat!
UnicornWizard is offline   Reply With Quote
Old 02-28-2020, 09:52 PM   #10
I use this method a lot. When I was reading the first part of the thread I was thinking I would post this method ... ya beat me to it!
I do like the "knock it on 3 or 4 directions" technique. I'll have to try it some time.
The thing about the notch method is that it works just as well AFTER you have stripped the screw head. If that does not work, the notch helps the cold chisel take the head off!
Old 02-29-2020, 04:17 PM   #11
Coachwork: Amtran RE
Chassis: International 3000
Engine: T444e 7.3L
An impact driver works much better than a simple drill or screw-gun. Also, the screws on my Amtran were #3 phillips, not #2.
Ultimately, I used the angle grinder on about 30 screws that I couldn't get out with the impact driver. It was easy and fast.
On the very last one, the red-hot screwhead fell on my driver's seat. The whole seat went up in flames in about 30 seconds. The fire destroyed the seat and seatbelt, cracked the driver's window, and melted the wiring going to the rear lights. Whoops.
Biscuitsjam is offline   Reply With Quote
Old 03-01-2020, 09:38 AM   #12
Engine: T444e 7.3L
Bus driver seats are flammable.
Old 03-01-2020, 01:42 PM   #13
Jeez that's scary.
Old 03-01-2020, 02:54 PM   #14
Use a #2 square bit on the phillips screws.
Old 03-04-2020, 06:19 PM   #15
Phatman's Avatar
Attachment 41955
Attachment 41954
Holy cow !!! I knew there was a reason why I keep a fire extinguisher on the bus. It’s always in my way. Must have moved that damn thing a 1000 times !!
Old 03-04-2020, 07:11 PM   #16
Go to Harbor freight and buy a 16$ air chisel(assuming you have access to an air compressor). You can hit each screw a few times with the air chisel, actually with a little practice, you can start the screw unthreading and finish up with drill and square bit. Has the same problem and this solved it easily.
Shotgun Navigation is offline   Reply With Quote
Old 03-05-2020, 12:23 AM   #17
Drill them out
Dirtdoctor is offline   Reply With Quote
Old 03-05-2020, 05:56 PM   #18
Chassis: Ford E450
Engine: Ford 7.3L Diesel Powerstoke
I just removed my ceiling panels on my Thomas shortie. They had those Philip-Square screw heads. I used an S2 (square #2) as was mentioned above. I go hundreds out that way, I did have a about a dozen that stripped out anyway and I had to cut a slot or even grind them so weak that a hammer and a heavy crow bar knocked the off (heads off), I then had to use vice grips to get the headless screws out. I never tried the left turning drill bit. That actualy sounds very good.
I also wanted to mention I used a hand ratcheting screwdriver for most of these rather than the electric torque/impact wrench or driver. They tend to "slip and strip". At least that was my experience.
Billb is offline   Reply With Quote
Old 07-21-2021, 10:51 PM   #19
Brilliant! This helped me out tremendously. Unfortunately tried going at a few with incorrect bit so I had a few that I had to cut out with grinder, but the square 2 bit, some wd 40, a chisel and mallet, starting a few clicks below full power on torque setting on my drill did the job on some 21 year old screws that had a pretty decent amount of rust.
Thanks and good luck!
DiddBiddy is offline   Reply With Quote
Old 07-21-2021, 10:54 PM   #20
Oh man!
Attachment 41955
Attachment 41954
I made sure to get my water hose out for the job because of this...
Also fire extinguishers are on the way.
Sorry that happened to you
conversion, gutted, panels, screws
