Old 12-31-2019, 10:47 AM   #1
TheHubbardBus's Avatar
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
How to vent 2 fresh water tanks?
We're going to have 2 fresh water tanks - on either side of the bus - linked together by a common line which will feed the pump (and also act as a drain). The tanks are inside the bus.
Tank 1 is being vented through the gravity fill cap. So no worries there. But that leaves tank 2. I'd really rather not buy another vented gravity-fill cap, as I only need one fill. But I don't know how else I can route this vent to the outside, above tank level, and also protect it from contamination/debris/a-holes.
Any ideas?
Go away. 'Baitin.
Our Build: Mr. Beefy
TheHubbardBus is offline   Reply With Quote
Old 12-31-2019, 11:54 AM   #2
I have 2 tanks, one above the other. The gravity feed port fills the top tank that also gravity feeds the bottom tank. The hose connecting the bottom tank will vent into the top tank and out the fill spout. If you have a line connecting your 2 tanks it should vent as well.
Old 12-31-2019, 01:12 PM   #3
Chassis: CE300
Rated Cap: 23
Nevermind, I'm having a brain fart kind of day.
Nothing to see here, please move along
Mods, if you feee the need to delete this thread, it won't hurt my feelings
Go away. 'Baitin.
