Originally Posted by cowlitzcoach
WOW!
I just knew it had to be something simple since you drove it into the shop.
I was NOT aware of the how the World Trans models were wired up. That is good to know that it uses power directly from the battery. Is the hot side fused?
I am sure glad the fix was simple although finding it was not.
Now that the bus is running again I would imagine your stomach is not in your throat full of bile. BTDT with a bus more than once.
It is extremely aggravating knowing that you drove it in but now you can't get it to start no matter what you do.
Now forward and onward with the conversion.
Good luck and happy trails to you!
Yeah man...felt sure it was simple, but just had to find it. I wasted a lot of time early really set on the fact it had to be the stop sign or roof hatches...or an interlock in general. That was the easiest, most sensible explanation, but...it was not to be. Definitely thought it could be the batteries also, but putting on the high amp charger early eliminated that one.
Literally ended up having to pull the dash, pull the top cover of the TCU and expose the back of the shift panel to figure it all out.
Diagrams show the wiring for the transmission to be pretty direct. It goes from battery, to that rear modular distribution, then forward to the front...no fuse. Once power goes inside the TCU, there is a fuse. Inside there are two fuses, so check both for continuity and for voltage with the key on. I tested at that fuse to an independent ground initially, and it showed good voltage. Then I decided to use the ground supply the TCU actually had as my ground and the voltage dropped dramatically. So, I knew it had to be directly in the TCM ground supply. At that point I started back at the battery, checked it...it was good. So, I figured well...gotta go under, no choice. I crawled in there behind the battery box and it was right there. The guy who helped me pull the seats must've kinked it, disturbed it or whatever and that was that.
Crazy online how many allison dead shift panels I found and how many rv'ers actually had similar problems. Loss of that ground or power feed between the back and the front strands quite a number of people. Problem is, the allison tcu is LOOT and some people replace it and it still won't start.
Big help was finding this link also. I didn't follow his procedure, because I did my own based on diagrams, but this is very helpful for anyone with the allison.
http://www.transmissioninstruments.c...eshooting.html
If you have a no start and your shift panel isn't lit up with the key in the on position, start right there. The shift panel is the neutral safety switch, and if it's not lit up, your bus isn't going to start.
