id have ti look and see but I think on my bluebird the door sashes are adjusted at both the top and the bottom for the alignment. my electric actuator is at the top and the door seems to seal pretty tight.. I like it as I dont have to see the ugly mechanism like it it were in the middle of the door. if you put it at the top its an easy project to just harvest the pieces from a jumkyard bus and go.
Not to discourage but the door opener mechanism on my shuttle bus is crazy complex, with two motors, four limit switches and a rat's nest of wires. Might not be all that simple, and, I'd worry a bit about how tight it closes.
It has an emergency lever to disengage as well.
