Originally Posted by jimmythomas
That sheet of steel is called the seat rail, and it is indeed structural. It connects the walls to the floor and is welded in place. It's a really good place to attach things like furniture and cabinets.
What he said, x2…. Structural!
I just started my framing and I am using 2x3 lumber screwed to each rib with 2 inch wood to metal screw ( tek screws) .
The rail on my bus measures 1 1/2 inches, same as the 2x3 boards. Once I put the face(plywood) on the posts it will come down nicely to the floor of the bus. I’ll be gluing insulation to the metal wall under the chair rail to fill in the air pocket created by my going this route.
