Leaks...AAAAHHHHH!!!!!
I had thought I had dealt with all my leaks previously, but I've been getting some pretty heavy rain this last weak and noticed a couple small leaks. Not an issue. I figured, hey, if I'm sealing these leaks up, I might as well make sure I seal every leak I have.
So today I went out there with a friend to hose the bus while I'm on the inside checking for leaks. Most don't seem to be a big deal, and hopefully I can get them sealed right up, but one leak I don't even know where to begin dealing with it.
Inside the walls, where you can access them by removing the metal panels, and factory insulation, the support beams are leaking water all over the inside walls. I haven't put insulation in the walls yet, but it would be a major concern if they are being exposed to that much water all the time. I don't think pink foam is meant to handle that amount of moisture. If that doesn't make sense, I can attach some photos or try to clarify further.
Any and all help on how to stop that kind of leak will be infinitely appreciated.
On a side note, it's VERY dirty inside those wall channels, and vacuuming hasn't really worked to clean them out. Any other ideas, or maybe I'll just have to try and forget about the dirt in the walls and pretend it's not there.
