Old 01-28-2020, 12:49 PM   #1
Member
LED Lights
My daughter just bought a school bus. We are trying to replace the backup lights and tail lifts with LED lights. Upon removing one of the backup lights, I found that there was only one lead. I am assuming that is the positive lead and the ground is to the frame by the screws holding the light assembly. The problem is that all the LED light that she purchased have three leads; a positive (red), a negative(black) and a ground. Any suggestions as to how to hook them up? I am going to try to hook the red to the one available lead and connect the black to the frame and see if that works. I apologize if the answer is in a previous thread but I could not find it. The bus is a 1990 International Wayne.
rkm767 is offline   Reply With Quote
Old 01-28-2020, 01:14 PM   #2
I just did the same thing and the packaging had the wiring instructions on it. Unfortunately I have tossed the packaging and don't remember.....
Old 01-28-2020, 01:51 PM   #3
I have the same lights. Hook the RED lead to whatever bus wire was hooked up to your backup light, and attach the WHITE wire to the bus frame with a screw or whatever. The black lead isn't connected to anything.
Old 01-28-2020, 02:50 PM   #4
brokedown's Avatar
Do you have a link or photo of your new and old lights? Would make it a lot easier to advise.
Old 01-28-2020, 03:09 PM   #5
Member
Thanks. I’ll try that.
Old 01-28-2020, 03:11 PM   #6
Member
No link but I’ll get some photos when I get back to the bus tomorrow. Thanks.
Old 01-28-2020, 07:42 PM   #7
Chassis: IH
Typical LED taillight wiring:
RED: "Bright" side of lights (brake/turn signals).
BLACK: "Dim" side of lights (Parking/tail lights).
WHITE: Ground.
You are correct, the old ones grounded through the mounting screws. In my case, when I swapped to LED's, I used the grounding points previously used by the 8-way flashers (since I had the inner sheetmetal off, and the 8-way bulbs were removed and had relatively easy access to it.)
