Originally Posted by Coamack1
I am not for certain on those particular lights but it may need a resistor in order to prevent hyper-flash. A normal light bulb with a filament has a higher resistance than led lights. Should be a simple fix if needed.
Actually, an incandescent bulb has a lower resistance and draws more current as a result . . . unless the LED light were to have a added on resistor to increase the current it uses to operate.
