Old 06-05-2022, 12:03 PM   #1
TheHubbardBus's Avatar
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
List of options to plug into data / diagnostic port?
I've skimmed a ton of threads talking about hardware/software 'plugged in' to the data / diagnostic port. It's a bit overwhelming. I'd like the ability to at least easily read error codes, but there appears to be potentially much more you can do, like create digital gauge panels, write as well as read from the ECM, etc.
Can anyone give me something like a high-level overview of what options are possible? I don't want to do something like purchase a scan tool and then find out I could have had a whole lot more cool functionality I didn't know to implement, or how to implement.
Thanks in advance. 2004 IC 3800 / t444e / Allison 2000
Go away. 'Baitin.
Our Build: Mr. Beefy
Old 06-05-2022, 07:50 PM   #2
Chassis: international
Engine: t444e
Rated Cap: short
I have Bluefire that can work on my andriod phone or windows 10 computer. Works but I have not driven the bus much as it needs tires so i just drive around town.
syntaxterror is offline   Reply With Quote
Old 06-07-2022, 11:55 AM   #3
Chassis: CE300
Rated Cap: 23
That looks like exactly what I'd like. I assume it displays error codes as well?
Is this the only / best game in town when it comes to this type of functionality?
Go away. 'Baitin.
Old 06-07-2022, 12:28 PM   #4
fo4imtippin's Avatar
Chassis: TC2000 28ft
I have a bluefire. its a bit of a pain. It disconnects a lot due to too much data through the interface. When i have time, i can change some parameters to try to fix the issue. I also might try out pairing with an IPAD (that i dont currently own) to see if that helps the stability. Honestly, for my use, i wish i would've gone with a ScanGuage D. I have a physical gauge for almost everything i want.
