Originally Posted by somewhereinusa
I would think that any splitting would be because wood, depending on species, splits.. Not because it is in a bus. Sycamore was splitting almost as fast as I was milling it. Maple, ash and walnut seem to be pretty stable once dried.
Hickory is beautiful wood but the worst for checks and cracks. Pine is second, because it is fast growing and typically has very high moisture content when green. Pine is the cheapest, so lots of people use it.
Most of the moisture escapes from the ends of the wood, and it's the differential drying that causes the wood to crack-dry wood shrinks. Controlling the drying by painting the end grain while it's curing is the ticket.
If you buy green, you'll need to cure it 6 months per inch of thickness, painting the end grain so it doesn't check. Even then, you may get checking so most woodworkers cut the wood over-long so the ends can be trimmed before using.
Lots of places sell live edge-give them a call and ask questions, they'll be happy to answer.
