Old 08-25-2020, 11:37 AM   #1
Looking at a 1996 bus to convert - Bad idea?
Hi Everyone! I'm new to the skoolie community and have been researching for weeks. I'm trying to find a bus to convert (approx. 27'-30' of interior space) and I found one, but it's from 1996. Is it a bad idea to convert an older bus versus a newer one? I'd appreciate any feedback. Thanks!
claudrea is offline   Reply With Quote
Old 08-25-2020, 11:48 AM   #2
Chassis: Vista 3600
Rated Cap: 24000 lbs
It will depend on the engine and trans combo first
but from what I learned if it is a T444E like mine is then at least 1998 is better so that trans upgrade to newer style transmissions is possible. It will have the appropriate plugs and wire harness, should you go a swap later
otherwise gonna be a variety of answers
RolesvilleMarina is offline   Reply With Quote
Old 08-25-2020, 12:25 PM   #3
Most 90-03 are what are desired. Newer than that the EPA came in with new regulations that added equipment that was prone to failure, hard to diagnose and expensive to repair. Mileage and maintenance are important factors the older they are.
