Old 06-11-2021, 12:51 PM   #1
Year: 2009
Coachwork: IC
Chassis: RE 300
Engine: DT 466 7.6L L6 DIESEL
Looking for advice on IC RE rear exit window seal
Hi all,
I recently bought my 2009 IC RE300 bus, and the rear window seal is really starting to break down on the outside edge. (Photos attached - not sure how to rotate them 90 degrees to the right)
Apparently the only part available from IC is the entire window, frame, and struts at $1200!
Wondering if there is someone who had a similar problem and came up with a more cost effective way to replace the back outer seal. Or if there's an equivalent outer seal I could get and modify.
Thanks!
ChrisHutchinson is offline   Reply With Quote
Old 06-11-2021, 09:10 PM   #2
Simplicity's Avatar
Coachwork: IC / Amtran
Chassis: 3000 / 33' Flat Nose
I have the same bus,
1) Auto window shop
2) https://www.tractorseats.com/p-3163-...ndow-seal.aspx
3) https://www.walmart.com/ip/Weather-S...90C1/947182032
4) Goop!
Steve
Old 06-11-2021, 10:04 PM   #3
ewo1's Avatar
Originally Posted by Simplicity View Post
https://www.steelerubber.com/rv-home-windows
https://www.pellandent.com/RV-Window-Seal
I used rivets and seam sealer on my back window, but that was just for the window frame itself.
ewo1 is online now   Reply With Quote
Old 06-11-2021, 10:18 PM   #4
Year: 2009
Coachwork: IC
Chassis: RE 300
These look really good.
I think my inner seal around the window is not too bad - it's the outer overlapping flat seal that is crumbling and doesn't cover the gap.
How did you use these - inner side of window or outer?
I bought new struts and want to be able to open the window at night for ventilation.
Thanks!
Old 06-11-2021, 10:39 PM   #5
Simplicity's Avatar
I haven't used any of these, as my windows are thankfully okay at this point.
I just did some quick searches and threw them up as suggestions. I hope they lead you to a good solution.
I've found many times, as you have with this issue, that there is not "perfect" "ready made" solution, or if there is, it's cost prohibitive or over-kill. So, I try to search outside the box for other possible solutions.
I've also gotten some great outside the box ideas from other posters that worked as well, if not better, easier and/or less costly than the generic solution.
Look forward to hearing what you ended up using and how it worked.
Steve
