New to the skoolie forum, so if I am not posting in the right please, sorry in advance. Need to know if this is a good deal, or if I should go onto the next.
1st school bus purchase, so I am as new as it gets. I will be converting this into our new home.
He is asking $4500
All the seats are removed. Some rust around the rear and sides, also under the bus. I think I can manage the rust issue.
He has installed a 5000 W inverter and deep cycle batteries, along with a Coleman Mach II 15,000 BTU rooftop A/C unit
These are the specs
2005 Thomas Built Saf-T-Liner MVP EF School Bus
with 83,957 miles on the odometer and 16,057 hours on meter
Caterpillar C7 7.2L L6 Diesel Engine
Allison automatic transmission
Single Axle
AC and Heat work
Spring suspension
Air Brakes
11R22.5 tires GVWR
36,350
Any info will help, mainly want to know if this is a good investment, or if I should look else where.
