Old 11-13-2019, 01:03 PM   #21
Chassis: TC1000 FE
Engine: 5.9
Originally Posted by BlackJohn View Post
Did you use a chipping hammer when running those beads?
No that's just straight out of the mig gun
lebusmagique is offline   Reply With Quote
Old 11-13-2019, 01:08 PM   #22
Chassis: TC1000 FE
Engine: 5.9
Here's another one going two pieces of 1/4". Disregard the splatter on the left and the beads in the center of the top piece that's from yesterday.Click image for larger version
It's got a few bugholes (?) At the end but I think it looks ok. Then again I just started welding yesterday so I don't know squat lol
Old 11-13-2019, 01:22 PM   #23
Originally Posted by TheHubbardBus View Post
Are there any jobs w/ your buses you have not being able to tackle with it, ECCB?
Its done a roof raise, tacked a couple catalytic converter heat shields, and a few other odd jobs. Its good for up to 1/4" or so, and I like how it welds for the $450 price.
I'd say its probably THE best buy for a budget part time welder.
Old 11-13-2019, 01:30 PM   #24
Originally Posted by lebusmagique View Post
Here's another one going two pieces of 1/4". Disregard the splatter on the left and the beads in the center of the top piece that's from yesterday.Attachment 39267
Looks pretty good to me, especially for the first time. All I did was burn holes in sheet metal my first time out. Only things I'd suggest is keep practicing to get your speed more consistent, and use a flap disk to take the pieces down to shiny metal where you're welding them (that will get rid of some of the slaggy bits).
I noticed you're welding outside (?), so the holes might be from your shielding gas being displaced by the wind briefly. On your first beads, I was going to recommend pausing at the end briefly before letting go of the trigger to prevent the crater at the end, but it looks like you're already doing that in the later pic.
Old 11-13-2019, 02:10 PM   #25
Chassis: TC1000 FE
Engine: 5.9
Thanks. Yeah this piece of 1/4" was straight out of the bin at TSC. No prep at all. I am outside and my cfh is at about 20. I reckon I could crank it up a little bit and see how that changes things. I did remember from the videos I watched how they would always hold the gun at the end of the weld before lifting it, so I did that.
Old 11-13-2019, 06:12 PM   #26
TheHubbardBus's Avatar
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
Thank you, sir!
Go away. 'Baitin.
Our Build: Mr. Beefy
Old 11-20-2019, 04:50 PM   #27
Handyman
I am not much of a metal worker. Looking at the structure around emergency exit in my Bluebird, I would not attempt to reproduce that structure without some good help.
I deleted mine.
My husband installed our lift in our 1993 Bluebird. There was no original opening for a lift. He fabricated the doors and it everything works perfectly. Not one problem with the mechanism or structure of the sidewall.
3bgees is offline   Reply With Quote
Old 11-20-2019, 05:00 PM   #28
Engine: 3208 turbo Cat
3bgees, can you provide photos? it would be interesting to see how He did it.
J
juliol is offline   Reply With Quote
Old 11-20-2019, 06:24 PM   #29
Our handicap entrance and two doors work beautifully. Not much hassle to do. Made my own doors on our 1993 Bluebird.
Old 11-30-2019, 01:43 PM   #30
Chassis: TC1000 FE
Engine: 5.9
ID:	39682Thinking about just riveting a panel of the new skin straight into the door frame here. It wouldn't be flush with the rest of the skin obviously but it seems like the easiest solution. thoughts?
Old 12-01-2019, 10:44 AM   #31
Attachment 39682Thinking about just riveting a panel of the new skin straight into the door frame here. It wouldn't be flush with the rest of the skin obviously but it seems like the easiest solution. thoughts?
981-314-1404 easier to explain over phone
Old 02-07-2020, 10:33 PM   #32
BusT's Avatar
Engine: Dt466e
Rated Cap: 30,000
I was sincere in my admiration. Not saying it can't be done. Just that I wouldn't have the guts to try it ;)
What Hobart did you get? I REALLY want a 210 MVP
I have the 210 mvp and am somewhat of a metal worker ... by trade at least and now kind of a neccesity... I love it ... want to try gas but flux core is doing fine ....
I’ve done some gates and little projects ... and before that did a roof rack on my ambulance van for solar and a hitch rack..
Then I tackled this transition similar to transcendence bus.
The Hobart is expensive and heavy hahah 90lbs i think
BusT is offline   Reply With Quote
Old 02-07-2020, 10:39 PM   #33
BusT's Avatar
Engine: Dt466e
Rated Cap: 30,000
Some times I kind of think the 140 would of suited me just fine ...
and be lighter .
Moving around the 210 is sometimes a chore ...
i like to put my welder in the garage every night and not leave it out when I’m not home ..... needless to say.
It really burns though and I did lots of light 22g and sheet metal work running on 240 also can burn 3/8 i think .... 5/16 for sure ... but i haven’t needed it for that yet ...
Old 02-07-2020, 10:42 PM   #34
BusT's Avatar
Engine: Dt466e
Rated Cap: 30,000
Hey Marc any detailed pics of the barn doors and how they latch?
Old 02-08-2020, 03:57 AM   #35
and be lighter .
I love my 140.
Old 02-08-2020, 06:15 PM   #36
BusT's Avatar
Engine: Dt466e
Rated Cap: 30,000
I love my 140.
And it’s almost half the price )
