Old 03-24-2020, 07:31 AM   #21
Originally Posted by Native View Post
With all the windows in a school bus, it is difficult to have decent physical security of the vehicle.
I'm not going to do this myself, but I was thinking that you could weld a vertical flat bar in the center of each window (or maybe even two) on the inside, which wouldn't really affect the windows but would prevent someone from being able to crawl in that way even if the window was entirely removed. With my bulkhead wall and the hatches securely fastened, you couldn't get in by just smashing a window - you'd have to cut something considerable.
Old 03-24-2020, 11:12 AM   #22
Originally Posted by sepudo View Post
Sooo, I really have to come up with a alternative for locking the service door other than with a padlock.
I had a sturdy lock on the latch that came with it when I bought it from the school and it got broken into and vandalized recently. Looks like they used a crowbar.
Mainly took my tool bag full of tools that I was using for the build and some odds and ends laying around inside.
At least they didn't break any glass.
I reeeally need to find a way to get the air doors to activate from the outside.
Sadly the damage to the doors is probably not enough to justify filing an insurance claim Attachment 42432Attachment 42433Attachment 42434Attachment 42435
If you install a latch as pictured above, when you are in the bus, lock the padlock on the "ring" side of the latch so nobody can latch you inside of the bus.
Don't ask how I know this......
Another bit of advice : If you ever find yourself needing to jump out of your bus window, don't do it wearing cowboy boots.....
Edit: pics aren't showing, see the post above.
Old 11-09-2020, 09:14 AM   #23
Locking our 2004 Thomas front door.
Eric, Did you ever find a way to lock the 2007 Thomas mostly glass door? Our 2004 Thomas is the same and I'm still trying to decide the best way to lock it if at all possible.
Originally Posted by STEMbus View Post
I am having the same issues with my 2007 Thomas Built School Bus, air operated main doors, that swing open outwards, split in the middle, and full glass. I'm currently researching to replace the doors with an RV door, as I have not found a sustainable solution to locking it up! Here is the picture of my doors. Has anyone else found an easier solution without replacing the doors?
Thanks,
Eric
BertM is offline   Reply With Quote
Electric door lock somewhereinusa Conversion General Discussions 6 10-27-2011 08:19 AM
this is how I lock my door on the bus lornaschinske Conversion General Discussions 5 12-26-2010 02:20 PM
door lock needed keith Classifieds | Buy, Sell, Swap 0 01-04-2009 11:23 AM
Rear door lock Kirbystud Conversion General Discussions 22 08-16-2005 03:47 AM
Door lock ideas Branden Conversion General Discussions 12 05-02-2005 06:47 PM
