Re: Need Carburetor help
from rereading the original post, if the tranny is having shifting problems because of the carb, then it is a vacuum issue.. That should be easy to fix without changing the carb, as either it takes an unrestricted vacuum supply, or one of the restricted ones. My guess so far is that is running either on no vacuum hooked up or on an unrestricted vaccum supply port. There should be a port in the base of the carb for a restricted vac supply, so i imagine it is just a question of maybe rerouting hoses or a fitting or "T" in the vacuum line.
