Old 03-30-2022, 03:19 AM   #1
Need door side defroster?
Hi folks,
My old girl, “BLUNDER-BUS” had 7 big fans to move air. I only kept the 3 next to drivers seat. Will that provide enough defrost, or should I rig up one of the blower fans on the door side?
Thanks.
donwynne is offline   Reply With Quote
Old 03-30-2022, 04:51 PM   #2
sportyrick's Avatar
Chassis: F33695
Filling in your information would help us determine where you live, the climate understood then we can comment on defrosters. You would want all the defrost you can get on those big windows.
Old 03-30-2022, 05:34 PM   #3
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
Originally Posted by donwynne View Post
Hi folks,
Thanks.
donwynne,
Freddy D was built for Central Florida & came stock without a door defroster or any floor heaters.
The three vents were tied to each other with a Y-connector.
There is, btw, a factory installed hole there. Terrific for additional road noise, drafts & varmints. Not great for our needs.
Many buses are built on IC Chassis. Worth addressing if you expose the area.
(I used upcycled wall steel)
You'll get more specific answers if you update your user profile.
Click on [User CP], then [Edit Details] add your bus details and location.
Old 03-31-2022, 10:39 AM   #4
In my opinion you don’t tear out any of the front heaters and defrosters .. I use my door heater all the time even when I don’t need the defrost. It keeps the cold air from the door area warm.. if you need storage that bad keep less stuff or buy a bigger bus
